The Platinum speaker by Our Pure Planet is a testament to sound quality and durability. Designed for portable use, it features an integrated microphone, making it perfect for hands-free calls, alongside a robust 3000 mAh rechargeable battery ensuring your music lasts. With Bluetooth 5.0, it offers versatile wireless connectivity, allowing you to stream your favorite tunes effortlessly. The speaker is not only water-resistant, thanks to its IPX4 rating, but also adheres to FSC standards, highlighting Our Pure Planet's commitment to environmental sustainability. Whether you're at home or on-the-go, the Platinum speaker delivers continuous power of 10 W, providing clear and powerful sound across a frequency response of 100 - 20000 Hz. Its comprehensive controls, including play/pause, volume adjustment, and power on/off, ensure a user-friendly experience. Embrace the blend of performance and portability with the Platinum speaker.
Versatile connectivity
Equipped with Bluetooth 5.0, the Platinum speaker from Our Pure Planet offers seamless wireless connectivity, allowing you to enjoy your favorite music without the hassle of wires. Its compatibility with a wide range of Bluetooth profiles, including A2DP, AVRCP, and HFP, ensures a versatile and comprehensive audio experience. -
Durable design
Designed with portability in mind, this speaker doesn't just bring your music wherever you go; it's also built to last. With an IPX4 water-resistant rating and compliance with FSC standards, the Platinum speaker is ready for any adventure, ensuring your music plays on, no matter the weather. -
Long-lasting battery life
The Platinum speaker is powered by a 3000 mAh rechargeable battery, offering extended playback time so you can enjoy your music for longer periods. USB charging options add convenience, making it easy to recharge the speaker wherever you are.
- Our Pure Planet Platinum - speaker - for portable use - wireless
- Product Type
- Speaker - for portable use
- Protection
- Water-resistant
- Speaker Type
- Active
- Continuous Power
- 10 Watt
- Frequency Response
- 100 - 20000 Hz
- Amplifier
- Integrated
- Bluetooth
- Speaker Details
- Speaker - 10 Watt - 100 - 20000 Hz - active
- Power Options
- USB charging
- Battery
- Speaker battery rechargeable
- 18.5 cm x 7.5 cm x 7.5 cm
- 500 g
- 2-year warranty
- Product Type
- Hands-Free Function
- Microphone
- Protection
- Water-resistant
Speaker System
- Speaker Type
- Active
- Continuous Power
- 10 Watt
- 100 - 20000 Hz
- Amplifier
- Integrated
- Bluetooth 5.0
- Bluetooth Profiles
- Advanced Audio Distribution Profile (A2DP), Audio/Video Remote Control Profile (AVRCP), Hands-Free Profile (HFP), Human Interface Device Profile (HID), Audio/Video Control Transport Protocol (AVCTP), Audio/Video Distribution Transport Protocol (AVDTP), Serial Port Profile (SPP)
- Controls
- Power on/off, volume, play/pause, play mode, call answer/end
Speaker System Details
- Speaker Details
- Speaker - 10 Watt - 100 - 20000 Hz CFR - active
- Driver Details
- Speaker: full-range driver
- Included Accessories
- Micro-USB charging cable
- IPX4, FSC
- Power Source
- Battery
- Options
- USB charging
- Rechargeable
- Capacity (Ah)
- 3000 mAh
- Run Time (Up To)
- 10 hour(s)
- 18.5 cm
- 7.5 cm
- 7.5 cm
- 500 g
- Limited warranty - 2 years
