Enjoy high quality sound and seamless connection, with the 700XHP True Wireless EarPods. Powered by Bluetooth 5.2, you can connect, listen, answer, chat and control your music with ease.
Maximum comfort comes as standard, with a compact size and premium earpods designed for long usage periods. And with waterproof technology, 700XHP True Wireless EarPods are made for adventure.
With up to 8 hours’ playback time from the earbuds and an additional 40 hours of battery life from the included charging case, these convenient EarPods will keep you listening for longer.
Even better, the 700XHP True Wireless EarPods give you powerful sound with less plastic impact. All our products are 200% plastic regenerative, 100% carbon neutral and use 100% sustainable packaging (FSC certified) - so you can listen well with added peace of mind.
2 year manufacturers warranty
                Wireless freedomExperience the freedom of movement with wireless connectivity technology, allowing you to enjoy your music without the hassle of tangled wires.
                Excellent sound qualityDelivers a wide frequency response of 20 - 20,000 Hz and a high sensitivity of 105 dB, ensuring a rich, clear, and dynamic audio experience.
                Long-lasting battery lifeEquipped with a rechargeable headphone battery, it offers extended playtime for all-day listening without the need for frequent recharging.
- Our Pure Planet 700XHP - true wireless earphones with mic
- Product Type
- True wireless earphones - Bluetooth
- Recommended Use
- Portable electronics
- Headphones Form Factor
- In-ear
- Wireless Technology
- Bluetooth
- Bluetooth Version
- Bluetooth 5.2
- Sound Output Mode
- Stereo
- Audio Specifications
- Frequency Response 20 - 20000 Hz - Sensitivity 105 dB +/- 3dB
- Impedance
- 16 Ohm
- Noise Isolating
- Microphones Included
- 2
- 2-year warranty
- Product Type
- True wireless earphones - Bluetooth - wireless
- Dimensions & Weight Details
- Charging case: 36.5 g
- 4.5 g
- Recommended Use
- Protection
- Waterproof
Audio Output
- In-ear
- Connectivity Technology
- Wireless
- Bluetooth
- Bluetooth Version
- Bluetooth 5.2
- Sound Output Mode
- Stereo
- Noise Isolating
- 20 - 20000 Hz
- Sensitivity
- 105 dB +/- 3dB
- Impedance
- 16 Ohm
- Diaphragm
- 8 mm
Microphone
- Form Factor
- Built-in
- 2
- Included Accessories
- Charging case
- Battery
- Headphone battery rechargeable
- Run Time (Up To)
- 8 hour(s)
- Run Time Details
- Continuous playback (with included charging case): up to 40 hours
- Recharge Time
- 2 hour(s)
- Limited warranty - 2 years
