OtterBox Utility Series/Latch II 10" Case
Quicklinx: 8YS8WS00 Mfr#: 77-30408
The Utility Series Latch II 10 inch tablet carrying case is perfect for holding the tablet while working, giving a presentation or teaching a class. This accessory easily attaches to your iPad protected by a Defender Series case with stretchy corner hooks. The hand strap is padded, adjusts to varying hand sizes and rotates to accommodate portrait or landscape viewing. An optional accessories bag contains an additional s-biner, leg strap and neck strap. This iPad carrying case is the ultimate utility accessory to use on your tablet for any activity or work situation.
  • Versatile carrying options
    Equipped with a carabiner, hand strap, and neck strap, this case offers multiple carrying options to suit any situation. The adjustable and padded straps ensure comfort and ease of use, whether on the move or stationary.
  • Enhanced protection and convenience
    Featuring a robust combination of Hypalon, polyester, and synthetic rubber materials, the case provides durable protection for tablets. The addition of a front external pocket, hook-and-loop strap, and rotating hand strap enhances convenience, allowing for easy access to your device and essentials.
  • Optimal tablet compatibility
    Designed to accommodate tablets up to 10 inches or 25.4 cm, ensuring a snug and secure fit for a wide range of devices. This compatibility makes it an ideal choice for tablet users seeking a reliable and protective case.
OtterBox Utility Series Latch II - case for tablet
Case for tablet
Screen Size Compatibility
10"
Material
Polyester, Hypalon, synthetic rubber
1-year warranty
Material
Carrying Case
Case
Recommended Use
For tablet
10"
Carrying Strap
Hand strap, neck strap, carabeener
Leg strap, accessory case
Touch fastener, removable neck strap, adjustable hand strap, front external pocket, adjustable neck strap, padded hand strap, rotating hand strap
1 year
