OtterBox Utility Series Latch II - Strap system for tablet - black - for Samsung Galaxy Tab Active 2 (8 in)
Versatile carrying options
Equipped with a removable neck strap, the OtterBox Utility Series Latch II offers flexible and comfortable carrying options for on-the-go users. -
Enhanced functionality
Featuring a rotating cover, this strap system allows for easy adjustment and versatile use, ensuring your tablet is always in the perfect position whether you're at work or on the move.
- OtterBox Utility Series Latch II - strap system for tablet
- Product Type
- 11.9 cm x 4.1 cm
- Dimensions - Diameter
- 22.8 cm
- 184 g
- Black
- Designed For
- Samsung Galaxy Tab Active2
- 11.9 cm
- 4.1 cm
- 22.8 cm
- 184 g
- Black
Carrying Case
- Strap system
- Recommended Use
- For tablet
- Carrying Strap
- Removable neck strap
- Additional Compartments
- Battery pack
- Included Accessories
- Stylus strap
- Cover Features
- Rotating
- Designed For
