The 100W OtterBox Four Port Wall Charger saves time by charging multiple devices at once. The four-port design of this GaN wall charger features dual USB-C and dual USB-A ports and charges up to 100W out of a single USB-C port. The OtterBox Four Port Wall Charger works seamlessly with Apple, Samsung, Google and other smartphone and tablet brands, while the adaptable power profile charges laptops with a 20V, 3A input. Enjoy safe, high-power delivery with USB-Power Delivery (PD).
Rigorously tested for durability, this fast-charging GaN wall charger keeps all your devices powered up.
- Compact, energy-efficient 100W four port fast charging GaN wall charger for convenient multi-device charging
 - Dual USB-C and dual USB-A ports
 - Up to 100W out of a single USB-C port
 - Fast and built to last, enjoy up to 58% charge to your smartphone in 30 minutes* *Based on iPhone 14 Pro
 - Passes rigorous tests for safe, smart and efficient home charging
 - Drop tested and wrapped in a tough exterior for ultra-durability
 - Works with Apple, Samsung, Google and other smartphone and tablet brands
 - Adaptable power profile charges laptops with a 20V, 3A input
Manufacturer warranty - 2 years
Efficient charging
Equipped with Gallium Nitride (GaN) technology, this wall charger offers efficient power delivery while minimizing heat production, ensuring your devices charge quickly and safely. -
Versatile connectivity
Featuring two USB-C and two USB-A ports, this power adapter allows simultaneous charging of multiple devices, catering to a wide range of charging needs. -
Advanced safety
Incorporated with smart charge technology and drop tested for durability, this power adapter provides a reliable and safe charging solution for your devices. -
Powerful performance
With a 100 W output and support for Power Delivery (PD), this charger is capable of powering up even the most demanding devices at full speed, ensuring you're always ready to go.
 - OtterBox - power adapter - 100 Watt
 - Power adapter - external
 - 294.22 g
- Localisation
 - Hong Kong, Malaysia, Singapore
- Output Voltage
 - 20 V
- Power Capacity
 - 100 Watt
- Input Connectors
 - Power Type G
 - 4.833 cm x 10.503 cm x 8.022 cm
- Localisation
- Input Connectors
 - Power Type G
- Output Voltage
 - 20 V
- Max Electric Current
 - 3 A
- Power Capacity
 - 100 Watt
 - 2 x USB-C - 24 pin USB-C , 2 x USB-A - 4 pin USB Type A
 - Power Delivery (PD), Gallium Nitride (GaN), drop tested, smart charge technology
 - 4.833 cm
 - 10.503 cm
 - 8.022 cm
 - 294.22 g
