OtterBox USB-C Four Port 100W Wall Charger
Quicklinx: HH5FWS00 Mfr#: 78-81349
Type: Charger
£45.61 ex VAT
£54.73 inc VAT
The 100W OtterBox Four Port Wall Charger saves time by charging multiple devices at once. The four-port design of this GaN wall charger features dual USB-C and dual USB-A ports and charges up to 100W out of a single USB-C port. The OtterBox Four Port Wall Charger works seamlessly with Apple, Samsung, Google and other smartphone and tablet brands, while the adaptable power profile charges laptops with a 20V, 3A input. Enjoy safe, high-power delivery with USB-Power Delivery (PD).
Rigorously tested for durability, this fast-charging GaN wall charger keeps all your devices powered up.
  • Compact, energy-efficient 100W four port fast charging GaN wall charger for convenient multi-device charging
  • Dual USB-C and dual USB-A ports
  • Up to 100W out of a single USB-C port
  • Fast and built to last, enjoy up to 58% charge to your smartphone in 30 minutes* *Based on iPhone 14 Pro
  • Passes rigorous tests for safe, smart and efficient home charging
  • Drop tested and wrapped in a tough exterior for ultra-durability
  • Works with Apple, Samsung, Google and other smartphone and tablet brands
  • Adaptable power profile charges laptops with a 20V, 3A input
Manufacturer warranty - 2 years
  • Efficient charging
    Equipped with Gallium Nitride (GaN) technology, this wall charger offers efficient power delivery while minimizing heat production, ensuring your devices charge quickly and safely.
  • Versatile connectivity
    Featuring two USB-C and two USB-A ports, this power adapter allows simultaneous charging of multiple devices, catering to a wide range of charging needs.
  • Advanced safety
    Incorporated with smart charge technology and drop tested for durability, this power adapter provides a reliable and safe charging solution for your devices.
  • Powerful performance
    With a 100 W output and support for Power Delivery (PD), this charger is capable of powering up even the most demanding devices at full speed, ensuring you're always ready to go.
OtterBox - power adapter - 100 Watt
Power adapter - external
294.22 g
Hong Kong, Malaysia, Singapore
Output Voltage
20 V
Power Capacity
100 Watt
Input Connectors
Power Type G
4.833 cm x 10.503 cm x 8.022 cm
Input Connectors
Power Type G
Output Voltage
20 V
Max Electric Current
3 A
Power Capacity
100 Watt
2 x USB-C - 24 pin USB-C , 2 x USB-A - 4 pin USB Type A
Power Delivery (PD), Gallium Nitride (GaN), drop tested, smart charge technology
4.833 cm
10.503 cm
8.022 cm
294.22 g
Type: Charger
Brand: OtterBox
