The 65W OtterBox Dual Port Wall Charger is the easy choice to quickly charge two devices at once. The compact design of this USB-C GaN wall charger works seamlessly to charge multiple devices from Apple, Samsung, Google and other smartphone and tablet brands, while the adaptable power profile charges laptops with a 20V, 3A input. Enjoy safe charging with USB-Power Delivery (PD) and Programmable Power Supply (PPS). Rigorously tested for durability and designed to work with your favourite OtterBox cable, this fast-charging GaN wall charger keeps your devices powered up and ready for anything.
Smart charging capability
Equipped with Smart Charge Technology, this wall charger intelligently adjusts to your device's power needs, ensuring efficient and safe charging for both cellular phones and tablets. -
High power output
Delivering a robust 65 Watt power output with a maximum electric current of 3 A, this charger supports fast charging technologies such as PD/PPS, making it ideal for quickly powering up your devices. -
Versatile connectivity
Featuring two output connectors, including a 24-pin USB-C, and compatible with power Type G input, this power adapter offers flexible charging solutions for a wide range of devices.
- OtterBox power adapter - 24 pin USB-C - 65 Watt
- Product Type
- Power adapter
- 3.793 cm x 7.468 cm x 4.046 cm
- 124.22 g
- Black
- Localisation
- Hong Kong, Malaysia, Singapore
- Output Connector Type
- Total 2: 24 pin USB-C
- Voltage Provided
- 20 V
- Max Electric Current
- 3 A
- Fast Charge Technology
- PD/PPS
- Power Provided
- 65 Watt
- Product Type
- Power adapter
- Designed For
- Tablet, mobile phone
- 3.793 cm
- 7.468 cm
- 4.046 cm
- 124.22 g
- Enclosure Colour
- Black
- Localisation
- Input Connectors
- Power Type G
- Input Connectors Qty
- 1
- Voltage Provided
- 20 V
- Output connectors
- Power Provided
- 65 Watt
- 3 A
- PD/PPS
- Smart Charge Technology, drop-tested
