OtterBox USB-C Dual Port 65W Wall Charger
Quicklinx: HH5GWS00 Mfr#: 78-81348
Type: Charger
£23.00 ex VAT
£27.60 inc VAT
The 65W OtterBox Dual Port Wall Charger is the easy choice to quickly charge two devices at once. The compact design of this USB-C GaN wall charger works seamlessly to charge multiple devices from Apple, Samsung, Google and other smartphone and tablet brands, while the adaptable power profile charges laptops with a 20V, 3A input. Enjoy safe charging with USB-Power Delivery (PD) and Programmable Power Supply (PPS). Rigorously tested for durability and designed to work with your favourite OtterBox cable, this fast-charging GaN wall charger keeps your devices powered up and ready for anything.
  • Smart charging capability
    Equipped with Smart Charge Technology, this wall charger intelligently adjusts to your device's power needs, ensuring efficient and safe charging for both cellular phones and tablets.
  • High power output
    Delivering a robust 65 Watt power output with a maximum electric current of 3 A, this charger supports fast charging technologies such as PD/PPS, making it ideal for quickly powering up your devices.
  • Versatile connectivity
    Featuring two output connectors, including a 24-pin USB-C, and compatible with power Type G input, this power adapter offers flexible charging solutions for a wide range of devices.
OtterBox power adapter - 24 pin USB-C - 65 Watt
Power adapter
3.793 cm x 7.468 cm x 4.046 cm
124.22 g
Hong Kong, Malaysia, Singapore
Output Connector Type
Total 2: 24 pin USB-C
Voltage Provided
20 V
Max Electric Current
3 A
Fast Charge Technology
PD/PPS
Power Provided
65 Watt
Power adapter
Tablet, mobile phone
3.793 cm
7.468 cm
4.046 cm
124.22 g
Enclosure Colour
Input Connectors
Power Type G
Input Connectors Qty
1
Voltage Provided
20 V
Output connectors
Power Provided
65 Watt
3 A
PD/PPS
Smart Charge Technology, drop-tested
Type: Charger
Brand: OtterBox
