OtterBox USB-A to USB-C cable is designed rugged for long-term use. It features an extended strain relief at that notorious weak spot where the cable and connector attach. It charges at 2.4 AMPs and its braided nylon avoids tangling itself into knots. Upgrade with the cable that's made to last.
                Efficient chargingWith a rated current of 2.4 A, this USB cable ensures your devices charge quickly and efficiently, minimizing wait times and boosting productivity.
                Durable designFeaturing strain relief and a tangle-free construction, this cable is designed for longevity and ease of use, ensuring it can withstand daily wear and tear without compromising performance.
- OtterBox - USB cable - 24 pin USB-C to USB - 3 m
- USB cable
- Strain relief, tangle-free
- Length
- 3 m
- Connector
- 24 pin USB-C - male
- Connector (Second End)
- 4 pin USB Type A - male
- Rated Current
- 2.4 A
- Black
- Limited lifetime warranty
- Designed For
- P/N: 77-53799, 77-53801, 77-53803, 77-55865, 77-59006, 77-60983, 77-60986, 77-60989, 77-60992, 77-61658, 77-61898, 77-61899, 77-62208, 77-62210, 77-62214, 77-62216, 77-62218, 77-63514, 78-51473, 78-51658, 78-51921, 78-52030, 78-52031, 78-52080, 78-52099, 78-52100, 78-52143, 78-52144, 78-52165
- USB cable
- Rated Current
- 2.4 A
- Length
- 3 m
- Black
- Connector
- Designed For
- P/N: 77-50779, 77-52008, 77-52018, 77-52030, 77-52629, 77-52802, 77-52803, 77-52828, 77-52874, 77-53670, 77-53681, 77-53695, 77-53799, 77-53801, 77-53803, 77-53946, 77-55410, 77-55698, 77-55780, 77-55781, 77-55782, 77-55783, 77-55798, 77-55823, 77-55824, 77-55825, 77-55828, 77-55829, 77-55865, 77-55866, 77-55876, 77-57760, 77-57791, 77-57792, 77-58499, 77-58503, 77-58770, 77-59006, 77-59037, 77-60983, 77-60986, 77-60989, 77-60992, 77-61658, 77-61898, 77-61899, 77-62208, 77-62210, 77-62214, 77-62216, 77-62218, 77-63514, 78-51295, 78-51296, 78-51297, 78-51300, 78-51301, 78-51308, 78-51313, 78-51315, 78-51326, 78-51331, 78-51335, 78-51338, 78-51339, 78-51355, 78-51392, 78-51399, 78-51423, 78-51453, 78-51454, 78-51455, 78-51462, 78-51463, 78-51464, 78-51465, 78-51473, 78-51658, 78-51663, 78-51664, 78-51921, 78-52030, 78-52031, 78-52080, 78-52099, 78-52100, 78-52143, 78-52144, 78-52165
