OtterBox USB-A to USB-C Cable - 3m
Quicklinx: D31KWS00 Mfr#: 78-51263
Length: 3m
£15.69 ex VAT
£18.82 inc VAT
OtterBox USB-A to USB-C cable is designed rugged for long-term use. It features an extended strain relief at that notorious weak spot where the cable and connector attach. It charges at 2.4 AMPs and its braided nylon avoids tangling itself into knots. Upgrade with the cable that's made to last.
OtterBox - USB cable - 24 pin USB-C to USB - 3 m
USB cable
Strain relief, tangle-free
Length
3 m
Connector
24 pin USB-C - male
Connector (Second End)
4 pin USB Type A - male
Rated Current
2.4 A
P/N: 77-53799, 77-53801, 77-53803, 77-55865, 77-59006, 77-60983, 77-60986, 77-60989, 77-60992, 77-61658, 77-61898, 77-61899, 77-62208, 77-62210, 77-62214, 77-62216, 77-62218, 77-63514, 78-51473, 78-51658, 78-51921, 78-52030, 78-52031, 78-52080, 78-52099, 78-52100, 78-52143, 78-52144, 78-52165
USB cable
Rated Current
2.4 A
Length
3 m
Connector
24 pin USB-C - male
P/N: 77-50779, 77-52008, 77-52018, 77-52030, 77-52629, 77-52802, 77-52803, 77-52828, 77-52874, 77-53670, 77-53681, 77-53695, 77-53799, 77-53801, 77-53803, 77-53946, 77-55410, 77-55698, 77-55780, 77-55781, 77-55782, 77-55783, 77-55798, 77-55823, 77-55824, 77-55825, 77-55828, 77-55829, 77-55865, 77-55866, 77-55876, 77-57760, 77-57791, 77-57792, 77-58499, 77-58503, 77-58770, 77-59006, 77-59037, 77-60983, 77-60986, 77-60989, 77-60992, 77-61658, 77-61898, 77-61899, 77-62208, 77-62210, 77-62214, 77-62216, 77-62218, 77-63514, 78-51295, 78-51296, 78-51297, 78-51300, 78-51301, 78-51308, 78-51313, 78-51315, 78-51326, 78-51331, 78-51335, 78-51338, 78-51339, 78-51355, 78-51392, 78-51399, 78-51423, 78-51453, 78-51454, 78-51455, 78-51462, 78-51463, 78-51464, 78-51465, 78-51473, 78-51658, 78-51663, 78-51664, 78-51921, 78-52030, 78-52031, 78-52080, 78-52099, 78-52100, 78-52143, 78-52144, 78-52165
Length: 3m
Brand: OtterBox
