OtterBox UK Wall Charger 20W - 1X USB-C 20W USB-PD Black
Quicklinx: HB1HWS00 Mfr#: 78-81216
OtterBox fast charge wall chargers are engineered rugged and built to outlast. Featuring a smart and compact design, this 20W wall charger is drop tested and wrapped in a tough exterior for years of use. Thoughtfully designed with advanced mobile expertise and proven quality that is uniquely durable, these tough wall chargers are designed to work flawlessly together with all OtterBox mobile power solutions - to build trust, foster connections and instill confidence for whatever the day brings. It's a 360° design approach you can count on to keep connected to the people, places and moments that matter most.
  • Fast charging capability
    Equipped with Power Delivery 3.0 technology, this wall charger ensures your devices are charged quickly. It can provide up to 20 W of power, reducing charging times for your cellular phone and tablet, keeping you connected without long waits.
  • Versatile compatibility
    Designed for both cellular phones and tablets, this power adapter offers a broad range of device compatibility. The inclusion of a 24-pin USB-C output connector type further enhances its versatility, making it a suitable charging solution for various USB-C enabled devices.
  • Durable design
    Drop-tested for durability, this wall charger is built to withstand daily use. Whether you're at home, in the office, or on-the-go, you can rely on this charger to remain functional and keep your devices powered up.
OtterBox power adapter - fast charge - USB-C - 20 watt
Power adapter
Mobile phone, tablet
4.29 cm x 2.9 cm x 4.98 cm
85.27 g
Black shimmer
Output Connector Type
USB-C
AC 100-240 V (50/60 Hz)
Voltage Provided
5 / 9 V
Max Electric Current
3 A
Fast Charge Technology
Power Delivery 3.0
Power Provided
20 watt
Power adapter
4.29 cm
2.9 cm
4.98 cm
85.27 g
Enclosure Colour
Black shimmer
Input Connectors
Power Type G
Voltage Provided
5 / 9 V
Output connectors
24 pin USB-C
Power Provided
20 watt
3 A
Power Delivery 3.0
Drop-tested
Packaging Type
Poly bag
USB Battery Charging Specification Rev. 1.2
Shipping Width
10.01 cm
Shipping Depth
5.99 cm
Shipping Height
10.01 cm
