Gear up your phone touchscreen for the long haul. OtterBox Trusted Glass installs easily and helps protect your screen from drops, breaks and scratches. The glass resists smudges and fingerprints while maintaining the vivid clarity of your display. You can rely on OtterBox Trusted Glass to guard your screen from random daily scrapes and tumbles.
Robust protection
Designed specifically for cellular phones, the OtterBox Trusted Glass screen protector offers a durable glass layer that shields your device's screen from scratches and impacts, ensuring it remains in pristine condition. -
Seamless compatibility
The Trusted Glass screen protector seamlessly fits your cellular phone, providing a clear, unobstructed view of your device's screen without compromising on touch sensitivity or clarity.
- OtterBox Trusted Glass - screen protector for mobile phone
- Product Type
- Screen protector - glass
- Intended For
- Mobile phone
- Protection
- Scratch-resistant, smudge-proof, fingerprint-proof, drop-proof
- Product Material
- Soda lime glass
- 6.92 cm 15.55 cm
- Thickness
- 0.5 mm
- Clear
- Limited lifetime warranty
- Designed For
- Samsung Galaxy A13 5G
- Product Type
- Package Type
- Retail
- Intended For
- Mobile phone
- Protection
- Product Material
- Soda lime glass
- 6.92 cm
- 15.55 cm
- Thickness
- 0.5 mm
- Clear
- Replacement - lifetime
- Designed For
Used stock
What is used stock?
Accessories | Packaging | Functional | Software | Manuals | ||
Ref:
H25W 048998 Condition: Customer return - item has been opened but is in excellent condition |
£0.91 |
Legend
This part of the stock item is present and in good condition
This part of the stock item is not present or functional
This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
This part of the stock item is not applicable e.g. it might not include accessories or software as standard
This item has not been tested.
