Focus on your fit without stressing your device safety with Symmetry Series for MagSafe. Ultra slim in a range of finishes, this thin case dials in your look while hugging your device’s curves. And now it features built-in anchors so you can customize your experience with straps and charms. All of your phone’s buttons, features and functions work flawlessly inside Symmetry Series for MagSafe. Plus, the integrated magnets snap securely to MagSafe accessories. And however you set your phone down, the screen lip and raised edges around the camera add an extra layer of protection.
Durable design
The rigid case design of the OtterBox Symmetry Series provides robust protection against drops and everyday wear, ensuring your device remains safe during accidental impacts. -
Convenient wireless charging
Equipped with built-in magnets, this case supports wireless charging, allowing for hassle-free powering up without the need to remove the case. -
Tactile accessibility
The tactile buttons integrated into the design ensure that accessing your phone's features is straightforward and user-friendly, enhancing the overall experience. -
Smart protection features
With raised edges around the camera and a screen lip, the case provides additional protection for sensitive areas, safeguarding your device from scratches and damage. -
Sustainable materials
Constructed from 40% recycled plastic, the Symmetry Series case not only protects your device but also contributes positively to the environment.
