The OtterBox Symmetry Series 360 offers robust protection for cell phones while maintaining a sleek appearance. Crafted from thermoplastic elastomer (TPE) and featuring a polycarbonate layer, this protective cover provides durability and comfort. Enhanced with built-in magnets and tactile buttons, it ensures ease of use without compromising style. Raised edges around the camera and a screen lip effectively guard against everyday wear and tear, making it an ideal companion for any user.
Designed with functionality in mind, this protective cover adheres to MIL-STD-810G 516.6 standards, ensuring reliable drop protection. Additionally, it features built-in anchors for secure attachment and is compatible with MagSafe technology. Made from 40% recycled plastic materials, the OtterBox Symmetry Series 360 protects devices and contributes to environmental sustainability.
Durable construction
Featuring a blend of thermoplastic elastomer and a polycarbonate layer, this protective cover is built to withstand impact while looking sleek. -
Enhanced usability
Equipped with built-in magnets and tactile buttons, this case ensures that accessing the phone's features is effortless and intuitive. -
Drop protection
Compliant with MIL-STD-810G 516.6 standards, this case delivers reliable defense against drops and bumps, keeping your device safe. -
Environmentally conscious
This product contains 40% recycled materials, making it a sustainable choice for those who want to reduce their environmental footprint. -
Secure fit
With built-in anchors and raised edges around the camera and screen lip, this case ensures your phone is securely protected from all angles.
- OtterBox Symmetry Series 360 - back cover for mobile phone
- Product Type
- Back cover for mobile phone - MagSafe compatibility
- 8.328 cm x 1.407 cm x 16.713 cm
- 36.63 g
- Material
- Polycarbonate layer, thermoplastic elastomer (TPE)
- Black
- Product Recycled Content
- 40 % - made from recycled plastic
- 7 years warranty
- Designed For
- Apple iPhone 16 Pro Max
- 8.328 cm
- 1.407 cm
- 16.713 cm
- 36.63 g
- Material
- Black
Carrying Case
- Protective cover
- Recommended Use
- For mobile phone
- Protection
- Drop+ protection, camera protection
- Cover Type
- Back cover
- Ultra-sleek design, built-in anchors, tactile buttons, raised edges around the camera, screen lip, rigid case design
- Cover Features
- Built-in magnets
- MagSafe Compatibility
- MIL-STD-810G 516.6
- Limited warranty - 7 years
- Designed For
Used stock
What is used stock?
Accessories | Packaging | Functional | Software | Manuals | ||
Ref:
J38V 051257 Condition: Customer return - item has been used and shows signs of use |
£9.06 |
Legend
This part of the stock item is present and in good condition
This part of the stock item is not present or functional
This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
This part of the stock item is not applicable e.g. it might not include accessories or software as standard
This item has not been tested.
