Flaunt your style and protect your device with the Symmetry Series case.
What do 24+ tests and 238+ hours of testing mean to you? They mean your OtterBox case is ready to dive into your day without a second thought — just like you are. OtterBox Certified Drop+ Protection means drops, bumps and fumbles are just the beginning. It means your device is protected from the barrage of wear & tear you subject it to everyday. So go ahead — do what you do and leave the protection to us.
- Ultra-slim: sleek profile follows the clean lines of the phone
- Style: complement your look with muted tones or soft pastels
- One-piece construction for simple, one-step installation
- Screen cover: elegant folio wraps around to protect the screen
- Card slot: vertical slot secures a card
- Stand: hands-free stand for easy viewing
Drop protection
Dual defensive layers protect your phone from bumps, drops and knocks. -
Card slot
Vertical slot secures a card or cash. -
Screen cover
Folio cover helps keep touchscreen free from scratches, scuffs and scrapes. -
Easy on/off
Case installs in a snap for instant protection.
- OtterBox Symmetry Series Apple iPhone 6/6s - flip cover for mobile phone
- Product Type
- Flip cover for mobile phone
- Black
- Black
Carrying Case
- Protective cover
- Recommended Use
- For mobile phone
- Cover Type
- Flip cover
- Open Type
- Side
