Show off your device without stressing its safety with Symmetry Series Clear for MagSafe. Ultra slim with a see-through finish, this clear case dials in your look while hugging your device’s curves. And now it features built-in anchors so you can customize your experience with straps and charms. All of your phone’s buttons, features and functions work flawlessly inside Symmetry Series Clear for MagSafe. Plus, the integrated magnets snap securely to MagSafe accessories. And however you set your phone down, the screen lip and raised edges around the camera add an extra layer of protection.
Durable construction
This case is designed with a rigid structure and built-in anchors that enhance durability while maintaining a lightweight feel. -
Convenient accessibility
Tactile buttons ensure easy access and responsiveness, allowing users to operate their phone effortlessly while protected. -
Enhanced protection
The screen lip and raised edges around the camera provide additional safeguarding against everyday drops and scratches. -
Eco-friendly materials
Made from 40% recycled plastic, this case combines quality protection with commitment to sustainability. -
Sleek aesthetics
The ultrasleek design of the case adds a stylish touch to your device, making it a fashionable accessory while keeping it safe.
Used stock
What is used stock?
Accessories | Packaging | Functional | Software | Manuals | ||
Ref:
J5C5 051180 Condition: Customer return - item has been used and shows signs of use |
£3.06 |
Ref:
J5C5 051303 Condition: Customer return - item has been opened but is in excellent condition |
£8.75 |
Legend
This part of the stock item is present and in good condition
This part of the stock item is not present or functional
This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
This part of the stock item is not applicable e.g. it might not include accessories or software as standard
This item has not been tested.
