OtterBox Symmetry Series Clear MagSafe for iPhone 16 Pro Max
Quicklinx: J5C5WS00 Mfr#: 77-96418
Hurry, only 3 left in stock!
£16.33 ex VAT
£19.59 inc VAT
Show off your device without stressing its safety with Symmetry Series Clear for MagSafe. Ultra slim with a see-through finish, this clear case dials in your look while hugging your device’s curves. And now it features built-in anchors so you can customize your experience with straps and charms. All of your phone’s buttons, features and functions work flawlessly inside Symmetry Series Clear for MagSafe. Plus, the integrated magnets snap securely to MagSafe accessories. And however you set your phone down, the screen lip and raised edges around the camera add an extra layer of protection.
  • Durable construction
    This case is designed with a rigid structure and built-in anchors that enhance durability while maintaining a lightweight feel.
  • Convenient accessibility
    Tactile buttons ensure easy access and responsiveness, allowing users to operate their phone effortlessly while protected.
  • Enhanced protection
    The screen lip and raised edges around the camera provide additional safeguarding against everyday drops and scratches.
  • Eco-friendly materials
    Made from 40% recycled plastic, this case combines quality protection with commitment to sustainability.
  • Sleek aesthetics
    The ultrasleek design of the case adds a stylish touch to your device, making it a fashionable accessory while keeping it safe.
OtterBox Symmetry Series - back cover for mobile phone
Back cover for mobile phone
Carrying Case
Protective cover
Recommended Use
For mobile phone
Cover Type
Back cover
Used stock
What is used stock?
Accessories Packaging Functional Software Manuals
Ref: J5C5 051180
Condition: Customer return - item has been used and shows signs of use
This part of the stock item is not applicable e.g. it might not include accessories or software as standard  This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.  This part of the stock item is present and in good condition  This part of the stock item is not present or functional  This part of the stock item is not present or functional  £10.20
Legend
  • This part of the stock item is present and in good conditionThis part of the stock item is present and in good condition
  • This part of the stock item is not present or functionalThis part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standardThis part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.This item has not been tested.
Brand: OtterBox
Stock Status: Used Stock
