Clearly display your phone with this case. This Symmetry case from OtterBox protects against drops, dings and scratches.
What do 24+ tests and 238+ hours of testing mean to you? They mean your OtterBox case is ready to dive into your day without a second thought — just like you are. OtterBox Certified Drop+ Protection means drops, bumps and fumbles are just the beginning. It means your device is protected from the barrage of wear & tear you subject it to everyday. So go ahead — do what you do and leave the protection to us.
- Clear: scratch-resistant case puts your phone on display
- Slim profile: sleek design slips easily into pockets and purses
- Screen bumper: raised, beveled edge helps protect touchscreen
- Easy installation: one-piece design slips on and off in a flash
- OtterBox Symmetry Series Apple iPhone 7 Plus - back cover for mobile phone
- Product Type
- Back cover for mobile phone
- Material
- Polycarbonate, synthetic rubber
- Black crystal
- 2-year warranty
- Material
- Black crystal
Carrying Case
- Protective cover
- Recommended Use
- For mobile phone
- Protection
- Scratch-resistant, drop-proof, tear-resistant, wear-resistant
- Cover Type
- Back cover
- 2 years
