Equip your teams to represent your business with a polished, professional appearance. Symmetry series antimicrobial Galaxy S23 case integrates an antimicrobial additive that helps inhibit microbial growth and helps defend the case exterior against many common bacteria. Your teams experience full phone functionality while achieving maximum productivity with Symmetry series guarding their phones. Easy to remove and install your teams have the confidence their critical business tech is protected and you have the assurance they are making the right impression.
Eco-friendly design
Crafted with 50% recycled plastic, this OtterBox Symmetry Series case combines sustainability with protection, making it an ideal choice for environmentally conscious consumers. -
Robust protection
Featuring drop+ protection and antimicrobial properties, this protective cover ensures your cell phone withstands the rigors of daily use while keeping it germ-free. -
Wireless charging compatible
Designed for convenience, the case supports wireless charging, allowing you to power up your device without removing the cover. -
Enhanced durability
Constructed from polycarbonate and synthetic rubber, this back cover offers a durable shield against scratches and impacts, ensuring your device remains in pristine condition. -
Precision fit
With raised edges and a design tailored for 5G compatibility, this case provides a snug fit while enhancing signal reception, offering both protection and performance.
- OtterBox Symmetry Series - back cover for mobile phone
- Product Type
- Back cover for mobile phone
- 7.77 cm x 1.12 cm x 15.12 cm
- Material
- Polycarbonate, synthetic rubber
- Black
- Product Recycled Content
- 50 % - made of recycled plastic
- Limited lifetime warranty
- Designed For
- Samsung Galaxy S23
- 7.77 cm
- 1.12 cm
- 15.12 cm
- Package Details
- Pro pack
- Material
- Black
Carrying Case
- Protective cover
- Recommended Use
- For mobile phone
- Protection
- Drop+ protection, antimicrobial
- Cover Type
- Back cover
- Raised edges, wireless charging support, 5G compatibility
- Limited warranty - lifetime
- Designed For
Used stock
What is used stock?
Accessories | Packaging | Functional | Software | Manuals | ||
Ref:
H6V9 051335 Condition: Customer return - item has been used and shows signs of use |
£8.80 |
Legend
This part of the stock item is present and in good condition
This part of the stock item is not present or functional
This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
This part of the stock item is not applicable e.g. it might not include accessories or software as standard
This item has not been tested.
