OtterBox Symmetry Samsung Galaxy S23 - Black
Quicklinx: H6V9WS00 Mfr#: 77-91140
Device Type: Samsung Galaxy
Type: Case
Product Range: OtterBox Symmetry Series
Product Model: Samsung Glaxay S23
£14.09 ex VAT
£16.90 inc VAT
Equip your teams to represent your business with a polished, professional appearance. Symmetry series antimicrobial Galaxy S23 case integrates an antimicrobial additive that helps inhibit microbial growth and helps defend the case exterior against many common bacteria. Your teams experience full phone functionality while achieving maximum productivity with Symmetry series guarding their phones. Easy to remove and install your teams have the confidence their critical business tech is protected and you have the assurance they are making the right impression.
  • Eco-friendly design
    Crafted with 50% recycled plastic, this OtterBox Symmetry Series case combines sustainability with protection, making it an ideal choice for environmentally conscious consumers.
  • Robust protection
    Featuring drop+ protection and antimicrobial properties, this protective cover ensures your cell phone withstands the rigors of daily use while keeping it germ-free.
  • Wireless charging compatible
    Designed for convenience, the case supports wireless charging, allowing you to power up your device without removing the cover.
  • Enhanced durability
    Constructed from polycarbonate and synthetic rubber, this back cover offers a durable shield against scratches and impacts, ensuring your device remains in pristine condition.
  • Precision fit
    With raised edges and a design tailored for 5G compatibility, this case provides a snug fit while enhancing signal reception, offering both protection and performance.
OtterBox Symmetry Series - back cover for mobile phone
Back cover for mobile phone
7.77 cm x 1.12 cm x 15.12 cm
Material
Polycarbonate, synthetic rubber
Product Recycled Content
50 % - made of recycled plastic
Samsung Galaxy S23
7.77 cm
1.12 cm
15.12 cm
Package Details
Pro pack
Material
Carrying Case
Protective cover
Recommended Use
For mobile phone
Protection
Drop+ protection, antimicrobial
Cover Type
Back cover
Raised edges, wireless charging support, 5G compatibility
Limited warranty - lifetime
Samsung Galaxy S23
Used stock
What is used stock?
Accessories Packaging Functional Software Manuals
Ref: H6V9 051335
Condition: Customer return - item has been used and shows signs of use
This part of the stock item is not applicable e.g. it might not include accessories or software as standard  This part of the stock item is not present or functional  This part of the stock item is present and in good condition  This part of the stock item is not present or functional  This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.  £8.32
Legend
  • This part of the stock item is present and in good conditionThis part of the stock item is present and in good condition
  • This part of the stock item is not present or functionalThis part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standardThis part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.This item has not been tested.
Type: Case
Brand: OtterBox
Stock Status: Used Stock
