Get the most out of your iPhone with Symmetry Series+ for MagSafe. This trendy iPhone case shows off iPhone's sleek design and was thoughtfully developed for seamless interaction with MagSafe charging and accessories. All of your phone's buttons, features and functions work flawlessly, while durable protection shields against drops, bumps and fumbles. And the one-piece design is easy to install. Proceed with confidence that your phone is protected, without sacrificing an ounce of style or functionality.
Eco-friendly construction
Crafted from 50% recycled plastic, polycarbonate, and synthetic rubber, this case combines sustainability with durability, offering a responsible choice for environmentally conscious consumers. -
Advanced protection
Featuring DROP+ technology and compliance with MIL-STD 810G 516.6 standards, this case provides superior drop protection. Its raised edges safeguard the screen and camera, ensuring your cell phone withstands everyday bumps and drops. -
Seamless functionality
Designed with a built-in magnet module and wireless charging support, this case enhances your device's functionality. Its ultra-sleek design does not compromise on protection or the ability to charge your phone effortlessly. -
Health-conscious design
An antimicrobial treatment on the case helps protect it by inhibiting the growth of bacteria on the surface, offering an added layer of cleanliness for your device.
- OtterBox Symmetry Series+ ProPack Packaging - back cover for mobile phone
- Product Type
- Back cover for mobile phone - MagSafe compatibility
- 8.38 cm x 1.41 cm x 16.69 cm
- Material
- Polycarbonate, synthetic rubber, 50% recycled plastic
- Black
- Limited lifetime warranty
- Designed For
- Apple iPhone 14 Pro Max
- 8.38 cm
- 1.41 cm
- 16.69 cm
- Package Details
- Polybag
- Material
- Black
Carrying Case
- Protective cover
- Recommended Use
- For mobile phone
- Protection
- Drop protection
- Cover Type
- Back cover
- Wireless charging support, raised edges, DROP+ technology, 5G compatibility, ultra-sleek design, built-in magnet module
- MagSafe Compatibility
- MIL-STD 810G 516.6
- Designed For
