Get the most out of your iPhone with Symmetry Series+ for MagSafe. This trendy iPhone case shows off iPhone's sleek design and was thoughtfully developed for seamless interaction with MagSafe charging and accessories. All of your phone's buttons, features and functions work flawlessly, while durable protection shields against drops, bumps and fumbles. And the one-piece design is easy to install. Proceed with confidence that your phone is protected, without sacrificing an ounce of style or functionality.
- OtterBox Symmetry Series+ - back cover for mobile phone
- Product Type
- Back cover for mobile phone - MagSafe compatibility
- 8.43 cm x 1.34 cm x 16.71 cm
- Material
- Polycarbonate, synthetic rubber, 50% recycled plastic
- Black
- Limited lifetime warranty
- Designed For
- Apple iPhone 14 Plus
- 8.43 cm
- 1.34 cm
- 16.71 cm
- Package Details
- Polybag
- Material
- Black
Carrying Case
- Protective cover
- Recommended Use
- For mobile phone
- Protection
- Antimicrobial, drop+ protection
- Cover Type
- Back cover
- Wireless charging support, raised edges, DROP+ technology, antimicrobial coating, 5G compatibility
- MagSafe Compatibility
- MIL-STD-810G 516.6
- Designed For
