OtterBox Symmetry Plus Clear for iPhone 14 Pro Max
Quicklinx: H0FVWS00 Mfr#: 77-89268
Device Type: Apple
Type: Case / Cover
Product Range: OtterBox Symmetry Series+
Product Model: iPhone 14 Pro Max
£15.61 ex VAT
£18.73 inc VAT
Get the most out of your iPhone with Symmetry Series+ clear for MagSafe. This iPhone 14 Pro Max clear case shows off iPhone's sleek design and was thoughtfully developed for seamless interaction with MagSafe charging and accessories. The stay clear formula preserves your case's crystal transparency. All of your phone's buttons, features and functions work flawlessly, while durable protection shields against drops, bumps and fumbles. And the one-piece design is easy to install. Proceed with confidence that your phone is protected, without sacrificing an ounce of style or functionality.
  • Eco-friendly design
    Crafted from 50% recycled plastic, this protective cover not only safeguards your cell phone but also contributes to a healthier planet. Its combination of polycarbonate and synthetic rubber materials ensures durability and grip, while the sleek design maintains the phone's slim profile.
  • Advanced protection
    Featuring an antimicrobial coating and raised edges, the OtterBox Symmetry Series+ case offers enhanced protection against microbes and screen damage. Its compliance with MIL-STD-810G 516.6 standards means your device is safeguarded against drops and bumps, ensuring peace of mind.
  • Wireless convenience
    Designed with MagSafe compatibility, this case supports wireless charging, allowing you to power up your device without removing the cover. The seamless integration with MagSafe accessories enhances your phone's functionality and convenience.
OtterBox Symmetry Series+ - back cover for mobile phone
Back cover for mobile phone - MagSafe compatibility
8.38 cm x 1.41 cm x 16.69 cm
Material
Polycarbonate, synthetic rubber, 50% recycled plastic
Clear
Apple iPhone 14 Pro Max
8.38 cm
1.41 cm
16.69 cm
Material
Clear
Carrying Case
Protective cover
Recommended Use
For mobile phone
Protection
Antimicrobial, drop+ protection
Cover Type
Back cover
Wireless charging support, raised edges, antimicrobial coating
MagSafe Compatibility
MIL-STD-810G 516.6
Device Type: Apple
Type: Case / Cover
Brand: OtterBox
