- The ultra-slim Symmetry for MagSafe Series, iPhone 15 Pro Max case undergoes thousands of hours of drop testing to ensure your smartphone gets the utmost protection.
- Protect your smartphone with ultra-slim Symmetry for MagSafe Series, the iPhone 15 Pro Max case that's easy to install and has 3 times as many drops as military standard ( MIL-STD-810G 516.6 ). That’s 78 individual drops from 4 feet.
- OtterBox Symmetry for MagSafe case has raised edges to protect your smartphone's camera and screen from serious drops and scrapes.
- Symmetry for MagSafe cases guarantee MagSafe compatibility thanks to built in magnets perfectly aligned to make wireless charging faster and easier than ever before. Seamlessly attach and remove MagSafe accessories through built in magnets.
- Made from 50% recycled plastic, OtterBox Symmetry for MagSafe Series provides flawless, sleek and stylish protection from scratches and cracks.
- Compatible with iPhone 15 Pro Max
The product is delivered without retail packaging to reduce environmental impacts by curtailing packaging waste. This helps us move closer to a more sustainable future.
Enhanced durability
Equipped with DROP+ technology and constructed from polycarbonate, silver phosphate glass, and synthetic rubber, this case offers superior drop protection. Its design meets the rigorous MIL-STD-810G 516.6 standards, ensuring your cell phone withstands the unexpected. -
Innovative protection
Featuring antimicrobial technology and shock-absorbent materials, the OtterBox Symmetry Series case actively fights off microbes and absorbs the force from drops and bumps, keeping your device clean and cushioned. -
Sleek functionality
With built-in magnets, this case supports MagSafe accessories, allowing for seamless integration with your device. The ultra-sleek design, combined with raised edges and tactile buttons, provides enhanced usability without compromising on style or protection.
- OtterBox Symmetry Series - back cover for mobile phone
- Product Type
- Back cover for mobile phone - MagSafe compatibility
- 8.45 cm x 1.44 cm x 16.61 cm
- Material
- Polycarbonate, synthetic rubber, silver phosphate glass
- Black
- Product Recycled Content
- 50 % - made of recycled plastic
- Limited lifetime warranty
- Designed For
- Apple iPhone 15 Pro Max
- 8.45 cm
- 1.44 cm
- 16.61 cm
- Package Details
- Polybag
- Material
- Black
Carrying Case
- Protective cover
- Recommended Use
- For mobile phone
- Protection
- Drop protection, shock-absorbent
- Cover Type
- Back cover
- Raised edges, tactile buttons, 5G compatibility, ultra-sleek design, antimicrobial technology, DROP+ technology
- Cover Features
- Built-in magnets
- MagSafe Compatibility
- MIL-STD-810G 516.6
- Limited warranty - lifetime
- Designed For
