- Compatible with iPhone 15 Pro MAX (Only)
- Ultra-sleek, stylish and trendy iPhone case made with more than 50% recycled plastic
- DROP+ 3X as many drops as military standard (MIL-STD-810G 516.6) works with wireless and MagSafe charging pads (no magnets in case)
- Raised edges protect camera and screen and case is easy to install and remove for quick style changes
Robust protection
Experience peace of mind with the OtterBox Symmetry Series case, designed to meet MIL-STD-810G 516.6 standards. Its combination of polycarbonate and synthetic rubber materials, along with reinforced edges and raised edges, offers superior protection against drops and impacts. -
Sleek and functional
The ultraslim design of the OtterBox Symmetry Series not only enhances your device's aesthetics but also supports 5G connectivity. Tactile buttons ensure ease of use, maintaining the functionality of your cell phone without compromise. -
Eco-conscious choice
Make a positive impact on the environment with the OtterBox Symmetry Series case. Made of 50% recycled plastic, it's a choice that benefits both your device and the planet.
- OtterBox Symmetry Series - back cover for mobile phone
- Product Type
- Back cover for mobile phone
- 8.45 cm x 1.44 cm x 16.61 cm
- Material
- Polycarbonate, synthetic rubber
- Black
- Product Recycled Content
- 50 % - made of recycled plastic
- Limited lifetime warranty
- Designed For
- Apple iPhone 15 Pro Max
- 8.45 cm
- 1.44 cm
- 16.61 cm
- Package Details
- Polybag
- Material
- Black
Carrying Case
- Protective cover
- Recommended Use
- For mobile phone
- Protection
- Drop+ protection
- Cover Type
- Back cover
- Raised edges, reinforced edges, tactile buttons, 5G compatibility, ultra-sleek design
- MIL-STD-810G 516.6
- Limited warranty - lifetime
- Designed For
