- Compatible with iPhone 15 Pro (Only)
- Ultra-sleek, stylish and trendy iPhone case made with more than 50% recycled plastic
- DROP+ 3X as many drops as military standard (MIL-STD-810G 516.6) works with wireless and MagSafe charging pads (no magnets in case)
- Raised edges protect camera and screen and case is easy to install and remove for quick style changes
Enhanced durability
Crafted from polycarbonate, silver phosphate glass, and synthetic rubber, this case offers robust protection against drops and impacts. Its compliance with MIL-STD-810G 516.6 standards ensures your cell phone withstands the rigors of daily use. -
Antimicrobial protection
Equipped with antimicrobial technology, the OtterBox Symmetry Series case actively inhibits microbial growth, keeping your device cleaner and safer to use. -
Thoughtful design
Featuring raised and reinforced edges, this case provides extra protection for your screen and camera. The ultra-sleek design maintains the phone's slim profile, while tactile buttons ensure easy access to all functions.
- OtterBox Symmetry Series - back cover for mobile phone
- Product Type
- Back cover for mobile phone
- 7.84 cm x 1.41 cm x 15.28 cm
- Material
- Polycarbonate, synthetic rubber, silver phosphate glass
- Black
- Product Recycled Content
- 50 % - made of recycled plastic
- Limited lifetime warranty
- Designed For
- Apple iPhone 15 Pro
- 7.84 cm
- 1.41 cm
- 15.28 cm
- Package Details
- Polybag
- Material
- Black
Carrying Case
- Protective cover
- Recommended Use
- For mobile phone
- Protection
- Drop+ protection
- Cover Type
- Back cover
- Raised edges, reinforced edges, tactile buttons, 5G compatibility, ultra-sleek design, antimicrobial technology
- MIL-STD-810G 516.6
- Limited warranty - lifetime
- Designed For
