OtterBox Symmetry iPhone 13/12 Pro Max
Quicklinx: GZTYWS00 Mfr#: 77-84262
Device Type: iPhone 13 Pro Max
Type: Case
Product Range: OtterBox Symmetry Series
Product Model: Apple iPhone 13 Pro Max
£15.20 ex VAT
£18.24 inc VAT
You don't have to choose between a protective case and a stylish one. Symmetry Series is the slim and protective case that shows off your style. All of your phone's buttons, features and functions work flawlessly. Additionally, a silver-based antimicrobial additive is integrated into the case that helps inhibit microbial growth and defends the case exterior against many common bacteria. And, Symmetry Series is easy to remove and install. Which is great because with all of the colors, you need more than just one.
  • Enhanced durability
    Equipped with DROP+ technology and compliant with MIL-STD-810G 516.6 standards, this OtterBox Symmetry Series case offers robust protection against drops, ensuring your cell phone withstands the rigors of daily use.
  • Sleek design
    The one-piece, ultraslim design not only adds minimal bulk to your device but also supports wireless charging, allowing for effortless power-ups without removing the case.
  • Comprehensive protection
    Featuring raised edges to safeguard your screen and camera, along with scratch protection, this hard case with soft grip provides all-around security for your cell phone.
  • Antimicrobial treatment
    This case is treated with an antimicrobial agent to inhibit the growth of odor-causing bacteria, offering a cleaner surface and added peace of mind.
  • MagSafe compatibility
    Designed with MagSafe compatibility, this protective cover ensures you can use all of your MagSafe accessories without any hindrance, enhancing the functionality of your cell phone.
OtterBox Symmetry Series - back cover for mobile phone
Back cover for mobile phone - MagSafe compatibility
Material
Polycarbonate, synthetic rubber
Material
Carrying Case
Protective cover
Recommended Use
For mobile phone
Protection
Scratch protection, drop+ protection
Cover Type
Back cover
Wireless charging support, raised edges, DROP+ technology, one-piece design, ultra-slim
MagSafe Compatibility
MIL-STD-810G 516.6
Lifetime
Type: Case
Brand: OtterBox
