You don't have to choose between a protective case and a stylish one. Symmetry Series is the sleek and protective case that shows off your style. All of your phone's buttons, features and functions work flawlessly. And Symmetry Series is easy to remove and install. From cute and fun to daring and dazzling, Symmetry Series is the slim, trendy iPhone case that delivers trusted OtterBox protection.
Sleek protection
The OtterBox Symmetry Series case combines an ultra-sleek design with synthetic rubber and polycarbonate materials, offering a slim profile that easily slides into pockets while providing robust protection against drops and impacts. -
Enhanced durability
Featuring DROP+ technology and compliance with MIL-STD 810G 516.6 standards, this case is engineered to withstand daily use, ensuring your cell phone remains protected against drops, bumps, and scrapes. -
Wireless convenience
Designed with modern needs in mind, this case supports wireless charging and is compatible with MagSafe, allowing for effortless charging without the need to remove the case. -
Antimicrobial protection
The case not only guards against physical damage but also includes antimicrobial protection, reducing the growth of bacteria on your phone's surface, promoting a cleaner surface. -
Eco-friendly choice
Committed to sustainability, the OtterBox Symmetry Series case is made of 50% recycled plastic, making it a choice that benefits both your phone and the planet.
- OtterBox Symmetry Series - back cover for mobile phone
- 8.38 cm x 1.41 cm x 16.69 cm
- Material
- Polycarbonate, synthetic rubber
- Black
- Product Recycled Content
- 50 % - made of recycled plastic
- Limited lifetime warranty
- Designed For
- Apple iPhone 14 Pro Max
- 8.38 cm
- 1.41 cm
- 16.69 cm
- Package Details
- Pro pack
- Material
- Black
Carrying Case
- Protective cover
- Recommended Use
- For mobile phone
- Protection
- Antimicrobial, drop protection
- Cover Type
- Back cover
- Wireless charging support, raised edges, DROP+ technology, 5G compatibility, ultra-sleek design
- MagSafe Compatibility
- MIL-STD 810G 516.6
- Lifetime
- Designed For
