OtterBox Symmetry for iPhone 14 Pro Max - Black
Quicklinx: H0FPWS00 Mfr#: 77-88526
Device Type: Apple
Type: Case / Cover
Product Range: OtterBox Symmetry Series
Product Model: iPhone 14 Pro Max
£14.36 ex VAT
£17.23 inc VAT
You don't have to choose between a protective case and a stylish one. Symmetry Series is the sleek and protective case that shows off your style. All of your phone's buttons, features and functions work flawlessly. And Symmetry Series is easy to remove and install. From cute and fun to daring and dazzling, Symmetry Series is the slim, trendy iPhone case that delivers trusted OtterBox protection.
  • Sleek protection
    The OtterBox Symmetry Series case combines an ultra-sleek design with synthetic rubber and polycarbonate materials, offering a slim profile that easily slides into pockets while providing robust protection against drops and impacts.
  • Enhanced durability
    Featuring DROP+ technology and compliance with MIL-STD 810G 516.6 standards, this case is engineered to withstand daily use, ensuring your cell phone remains protected against drops, bumps, and scrapes.
  • Wireless convenience
    Designed with modern needs in mind, this case supports wireless charging and is compatible with MagSafe, allowing for effortless charging without the need to remove the case.
  • Antimicrobial protection
    The case not only guards against physical damage but also includes antimicrobial protection, reducing the growth of bacteria on your phone's surface, promoting a cleaner surface.
  • Eco-friendly choice
    Committed to sustainability, the OtterBox Symmetry Series case is made of 50% recycled plastic, making it a choice that benefits both your phone and the planet.
OtterBox Symmetry Series - back cover for mobile phone
8.38 cm x 1.41 cm x 16.69 cm
Material
Polycarbonate, synthetic rubber
Product Recycled Content
50 % - made of recycled plastic
Apple iPhone 14 Pro Max
8.38 cm
1.41 cm
16.69 cm
Package Details
Pro pack
Material
Carrying Case
Protective cover
Recommended Use
For mobile phone
Protection
Antimicrobial, drop protection
Cover Type
Back cover
Wireless charging support, raised edges, DROP+ technology, 5G compatibility, ultra-sleek design
MagSafe Compatibility
MIL-STD 810G 516.6
Lifetime
Device Type: Apple
Type: Case / Cover
Brand: OtterBox
