You don't have to choose between a protective case and a stylish one. Symmetry Series is the sleek and protective case that shows off your style. All of your phone's buttons, features and functions work flawlessly. And Symmetry Series is easy to remove and install. From cute and fun to daring and dazzling, Symmetry Series is the slim, trendy iPhone case that delivers trusted OtterBox protection.
Sleek protection
The OtterBox Symmetry Series case combines an ultra-sleek design with synthetic rubber and polycarbonate materials, offering a slim profile that easily slips into pockets while providing robust protection against drops and impacts. -
Enhanced durability
Engineered with DROP+ technology and compliant with MIL-STD 810G 516.6 standards, this protective cover is designed to withstand the rigors of daily use, ensuring your cell phone remains safe from accidental drops and bumps. -
Convenient features
Featuring raised edges to protect the screen and camera, wireless charging support for easy power-ups, and MagSafe compatibility for a seamless experience with Apple accessories. The antimicrobial protection helps keep your device hygienic, making it an ideal choice for everyday use. -
Eco-friendly choice
With 50% of its composition made from recycled plastic, the OtterBox Symmetry Series case not only protects your device but also supports environmental sustainability. Its commitment to using recycled materials reflects a step forward in eco-conscious product design.
- OtterBox Symmetry Series - back cover for mobile phone
- Product Type
- Back cover for mobile phone - MagSafe compatibility
- 7.77 cm x 1.42 cm x 15.37 cm
- Material
- Polycarbonate, synthetic rubber
- Black
- Product Recycled Content
- 50 % - made of recycled plastic
- Limited lifetime warranty
- Designed For
- Apple iPhone 14 Pro
- 7.77 cm
- 1.42 cm
- 15.37 cm
- Package Details
- Polybag
- Material
- Black
Carrying Case
- Protective cover
- Recommended Use
- For mobile phone
- Protection
- Antimicrobial, drop protection
- Cover Type
- Back cover
- Wireless charging support, raised edges, DROP+ technology, 5G compatibility, ultra-sleek design
- MagSafe Compatibility
- MIL-STD 810G 516.6
- Lifetime
- Designed For
