OtterBox Symmetry for iPhone 14 Pro - Black
Quicklinx: H0F0WS00 Mfr#: 77-88505
Device Type: Apple
Type: Case / Cover
Product Range: OtterBox Symmetry Series
Product Model: iPhone 14 Pro
£14.23 ex VAT
£17.07 inc VAT
You don't have to choose between a protective case and a stylish one. Symmetry Series is the sleek and protective case that shows off your style. All of your phone's buttons, features and functions work flawlessly. And Symmetry Series is easy to remove and install. From cute and fun to daring and dazzling, Symmetry Series is the slim, trendy iPhone case that delivers trusted OtterBox protection.
  • Sleek protection
    The OtterBox Symmetry Series case combines an ultra-sleek design with synthetic rubber and polycarbonate materials, offering a slim profile that easily slips into pockets while providing robust protection against drops and impacts.
  • Enhanced durability
    Engineered with DROP+ technology and compliant with MIL-STD 810G 516.6 standards, this protective cover is designed to withstand the rigors of daily use, ensuring your cell phone remains safe from accidental drops and bumps.
  • Convenient features
    Featuring raised edges to protect the screen and camera, wireless charging support for easy power-ups, and MagSafe compatibility for a seamless experience with Apple accessories. The antimicrobial protection helps keep your device hygienic, making it an ideal choice for everyday use.
  • Eco-friendly choice
    With 50% of its composition made from recycled plastic, the OtterBox Symmetry Series case not only protects your device but also supports environmental sustainability. Its commitment to using recycled materials reflects a step forward in eco-conscious product design.
OtterBox Symmetry Series - back cover for mobile phone
Back cover for mobile phone - MagSafe compatibility
7.77 cm x 1.42 cm x 15.37 cm
Material
Polycarbonate, synthetic rubber
Product Recycled Content
50 % - made of recycled plastic
Apple iPhone 14 Pro
7.77 cm
1.42 cm
15.37 cm
Package Details
Polybag
Material
Carrying Case
Protective cover
Recommended Use
For mobile phone
Protection
Antimicrobial, drop protection
Cover Type
Back cover
Wireless charging support, raised edges, DROP+ technology, 5G compatibility, ultra-sleek design
MagSafe Compatibility
MIL-STD 810G 516.6
Lifetime
Apple iPhone 14 Pro
Device Type: Apple
Type: Case / Cover
Brand: OtterBox
