OtterBox Symmetry Core Series MagSafe for iPhone 16 Pro Max - Carnival Night
Quicklinx: J5C8WS00 Mfr#: 77-95928
£22.54 ex VAT
£27.04 inc VAT
Focus on your fit without stressing your device safety with Symmetry Series Core for MagSafe. Ultra-slim with a soft-touch feel, this MagSafe case features flecks of reground silicone for a uniquely recycled style. And now it features built-in anchors so you can customize your experience with straps and charms. All of your phone’s buttons, features and functions work flawlessly inside Symmetry Series Core for MagSafe. Plus, the integrated magnets snap securely to MagSafe accessories. And however you set your phone down, the screen lip and raised edges around the camera add an extra layer of protection.
  • Durable Protection
    This protective cover features advanced drop+ protection that meets MIL-STD-810G 516.6 standards, providing confidence in the safety of your device during everyday use.
  • Eco-Friendly Materials
    Composed of 45% recycled plastic, this case safeguards your cell phone and supports environmental sustainability through responsible recycling practices.
  • User-Friendly Design
    Designed with raised edges and tactile buttons, the case ensures that all device functions remain easily accessible while providing reliable protection from potential damage.
  • Wireless Charging Compatibility
    Seamlessly compatible with wireless charging systems, this case allows for convenient recharging without the hassle of removing the cover.
  • Soft Touch Finish
    The soft touch finish of the case provides a comfortable grip, making it easy to hold and use the phone with confidence.
OtterBox Symmetry Core Series - back cover for mobile phone
Back cover for mobile phone - MagSafe compatibility
8.558 cm x 1.443 cm x 16.903 cm
46.62 g
Finish
Soft touch
Carnival night (black)
Product Recycled Content
45 % - made of recycled plastic
7 years warranty
Apple iPhone 16 Pro Max
8.558 cm
1.443 cm
16.903 cm
46.62 g
Finish
Soft touch
Carrying Case
Protective cover
Recommended Use
For mobile phone
Protection
Drop+ protection
Cover Type
Back cover
Ultra-thin, wireless charging support, raised edges, tactile buttons
MagSafe Compatibility
MIL-STD-810G 516.6
Limited warranty - 7 years
Brand: OtterBox
