You don't have to choose between a protective case and a stylish one. Symmetry Series is the slim and protective case that shows off your style. All of your phone's buttons, features and functions work flawlessly. Additionally, a silver-based antimicrobial additive is integrated into the case that helps inhibit microbial growth and defends the case exterior against many common bacteria. And, Symmetry Series is easy to remove and install. Which is great because with all of the colors, you need more than just one.
Enhanced durability
Crafted from polycarbonate and synthetic rubber, this protective cover offers robust defense against daily wear and tear. Its materials ensure longevity and resilience, safeguarding your cell phone from the rigors of everyday use. -
Innovative protection
Featuring DROP+ technology and compliant with MIL-STD-810G 516.6 standards, this case is engineered to provide superior drop protection. Its one-piece design and raised edges further enhance its ability to shield your device from impacts and scratches. -
Sleek functionality
Designed with an ultraslim profile, this back cover does not compromise on protection. It supports wireless charging, allowing for convenient power-ups without the need to remove the case. The antimicrobial treatment adds an extra layer of hygiene by reducing the growth of bacteria on your device.
- OtterBox Symmetry Series Clear - back cover for mobile phone
- Product Type
- Back cover for mobile phone
- 7.74 cm x 1.17 cm x 15.22 cm
- Material
- Polycarbonate, synthetic rubber
- Clear
- Limited lifetime warranty
- Designed For
- Samsung Galaxy S22
- 7.74 cm
- 1.17 cm
- 15.22 cm
- Package Details
- Pro pack
- Material
- Clear
Carrying Case
- Protective cover
- Recommended Use
- For mobile phone
- Protection
- Drop protection
- Cover Type
- Back cover
- DROP+ technology, ultra-slim, wireless charging support, one-piece design, raised edges
- MIL-STD-810G 516.6
- Designed For
