- The ultra-slim Symmetry Clear for MagSafe Series for iPhone 15 Pro Max case undergoes thousands of hours of drop testing to ensure your smartphone gets the utmost protection
- Protect your smartphone with ultra-slim Symmetry Clear for MagSafe Series, the iPhone 15 Pro Max case that's easy to install and has 3 times as many drops as military standard ( MIL-STD-810G 516.6 ). OtterBox Symmetry Clear for MagSafe case has raised edges to protect your smartphone's camera and screen from serious drops and scrapes.
- Symmetry Clear for MagSafe cases guarantee MagSafe compatibility thanks to built in magnets perfectly aligned to make wireless charging faster and easier than ever before. Seamlessly attach and remove MagSafe accessories through built in magnets.
- Made from 50% recycled plastic, OtterBox Symmetry Clear for MagSafe Series provides flawless, sleek and stylish protection from scratches and cracks.
- Compatible with iPhone 15 Pro Max
The product is delivered without retail packaging to reduce environmental impacts by curtailing packaging waste.
Enhanced durability
Crafted from polycarbonate and synthetic rubber, this OtterBox Symmetry Series Clear case offers robust protection. Its design meets MIL-STD-810G 516.6 standards, ensuring your cell phone withstands the rigors of daily use. -
Innovative protection
Featuring drop+ protection and a shock-absorbent material, this case is engineered to shield your device from impacts. Raised and reinforced edges provide additional security for your phone's screen and camera. -
Designed with built-in magnets, this case supports MagSafe accessories, allowing for seamless attachment and faster wireless charging without sacrificing protection. -
Eco-friendly choice
With 50% of its composition made from recycled plastic, this case is a step towards sustainability without compromising on quality or protection.
- OtterBox Symmetry Series Clear - back cover for mobile phone
- Product Type
- Back cover for mobile phone - MagSafe compatibility
- 8.45 cm x 1.44 cm x 16.61 cm
- Material
- Polycarbonate, synthetic rubber
- Clear
- Product Recycled Content
- 50 % - made of recycled plastic
- Limited lifetime warranty
- Designed For
- Apple iPhone 15 Pro Max
- 8.45 cm
- 1.44 cm
- 16.61 cm
- Package Details
- Polybag
- Material
- Clear
Carrying Case
- Protective cover
- Recommended Use
- For mobile phone
- Protection
- Drop protection, drop+ protection, shock-absorbent
- Cover Type
- Back cover
- Raised edges, reinforced edges, tactile buttons, 5G compatibility, ultra-sleek design
- Cover Features
- Built-in magnets
- MagSafe Compatibility
- MIL-STD-810G 516.6
- Limited warranty - lifetime
- Designed For
