- Compatible with iPhone 15 Pro (Only)
- Ultra-sleek and stylish iPhone 15 Pro clear case is made with more than 50% recycled plastic
- DROP+ 3X as many drops as military standard (MIL-STD-810G 516.6) works with wireless and MagSafe charging pads (snaps to MagSafe)
- Raised edges protect camera and screen and case is easy to install and remove for quick style changes
Enhanced durability
Crafted from polycarbonate and synthetic rubber, this protective cover offers exceptional durability against drops and shocks. Its adherence to MIL-STD-810G 516.6 standards ensures your cell phone withstands the rigors of daily use. -
Innovative design
The OtterBox Symmetry Series case features a back cover with built-in magnets, raised and reinforced edges, and speaker holes, all contributing to its ultra-sleek design. This thoughtful construction not only enhances the aesthetic appeal but also ensures functionality with 5G compatibility and wireless charging support. -
Eco-friendly choice
With 50% of its composition made from recycled plastic, this case represents a commitment to environmental sustainability without compromising on protection or style. Choosing this case means you're protecting your device while contributing to a healthier planet.
- OtterBox Symmetry Series - back cover for mobile phone
- Product Type
- Back cover for mobile phone - MagSafe compatibility
- 7.84 cm x 1.41 cm x 15.28 cm
- Material
- Polycarbonate, synthetic rubber
- Clear
- Product Recycled Content
- 50 % - made of recycled plastic
- Limited lifetime warranty
- Designed For
- Apple iPhone 15 Pro
- 7.84 cm
- 1.41 cm
- 15.28 cm
- Package Details
- Pro pack
- Material
- Clear
Carrying Case
- Protective cover
- Recommended Use
- For mobile phone
- Protection
- Drop+ protection, shock-absorbent
- Cover Type
- Back cover
- Wireless charging support, raised edges, reinforced edges, speaker holes, 5G compatibility, ultra-sleek design
- Cover Features
- Built-in magnets
- MagSafe Compatibility
- MIL-STD-810G 516.6
- Limited warranty - lifetime
- Designed For
