Ensure safety of your devices with the OtterBox Symmetry MagSafe Case. Features like raised edges and tactile buttons enhance the utility of the case. It also comes with built-in magnets, which firmly attach to chargers and other accessories. This case is compatible with the Apple iPhone 15/14 Plus.
- Compatible with Apple iPhone 15/14 Plus
- Ultra-sleek Design that Flows with the Lines
- Raised Edges Around the Camera
- Works with OtterBox Screen Protection
- Built-in Magnets Snap Firmly to MagSafe Chargers and Accessories
- Rigid Case Design with Reinforced Corners for Shock Absorption
- Tactile Buttons Feel Just Like Your phone
Enhanced durability
Crafted from polycarbonate and synthetic rubber, this protective cover offers a rigid case design that withstands the rigors of daily use. Its compliance with MIL-STD-810G 516.6 standards ensures it can handle bumps and drops, providing peace of mind for the user. -
Magnetic integration
Designed with built-in magnets, this case is fully compatible with MagSafe accessories, allowing for seamless attachment and enhancing the user experience with a range of compatible products. -
Thoughtful design
Featuring a raised camera bezel, this back cover not only protects the phone's camera from scratches and damage but also maintains 5G compatibility, ensuring that your device's connectivity is not compromised.
- OtterBox Symmetry Series - back cover for mobile phone
- Product Type
- Back cover for mobile phone
- 8.56 cm x 1.34 cm x 16.7 cm
- 44 g
- Material
- Polycarbonate, synthetic rubber
- Clear
- Product Recycled Content
- 50 % - made of recycled plastic
- Limited lifetime warranty
- Designed For
- Apple iPhone 14 Plus, 15 Plus
- 8.56 cm
- 1.34 cm
- 16.7 cm
- 44 g
- Material
- Clear
Carrying Case
- Protective cover
- Recommended Use
- For mobile phone
- Protection
- Bump protection, drop+ protection
- Cover Type
- Back cover
- 5G compatibility, raised camera bezel, rigid case design, built in magnets
- MILD-STD-810G 516.6
- Designed For
