- Protect your smartphone with ultra-slim Symmetry MagSafe Clear series, the iPhone 15 Pro Max transparent case that's easy to install and has 3 times as many drops as military standard ( MIL-STD-810G 516.6 ). OtterBox Symmetry MagSafe case has raised edges to protect your smartphone's camera and screen from serious drops and scrapes. Clear case shows off your phone's elegant design while protecting against drops, dings and scratches.
- Made from 50% recycled plastic, OtterBox Symmetry MagSafe Clear Series provides flawless, sleek and stylish protection from scratches and cracks.
- Symmetry MagSafe Clear cases guarantee MagSafe compatibility thanks to built in magnets perfectly aligned to make wireless charging faster and easier than ever before. Seamlessly attach and remove MagSafe accessories through built in magnets.
- The crystal-clear Premium Glass Screen Protector is an ultra-thin tempered glass, made with fortified material technology to withstand drops, breaks, scratches and daily wear. Plus, it’s fingerprint resistant, so you can touch, tap and swipe while your screen stays smudge-free.
- OtterBox Premium Glass delivers advanced anti-scratch defence for vivid screen clarity and shatter-resistant drop protection.
- Fortified material resists splintering and the reinforced edges prevent chipping, while maintaining touch sensitivity and display clarity.
- Compatible with iPhone 15 Pro Max
- Reduced Waste Packaging: At OtterBox we’ve taken concrete steps to reduce our impact, that’s why we made our retail packaging from sustainable materials that are fully recyclable and use nearly no plastic.
Wireless charging support
Enjoy the convenience of wireless charging without the need to remove the case. The OtterBox Symmetry Series Clear case is designed to support wireless charging, ensuring your cell phone stays protected while powering up. -
This case is fully compatible with MagSafe accessories, offering a seamless experience with your MagSafe charger and other accessories. The strong magnetic alignment and attachment make your daily charging and accessory use hassle-free.
- OtterBox Symmetry Series Clear - back cover for mobile phone
- Product Type
- Back cover for mobile phone - MagSafe compatibility
- Bundled with
- Premium Glass Screen protector
- Clear
- Limited lifetime warranty
- Package Type
- Retail
- Clear
Carrying Case
- Protective cover
- Bundled with
- Recommended Use
- For mobile phone
- Cover Type
- Back cover
- Wireless charging support
- MagSafe Compatibility
- Lifetime
