- Protect your smartphone with ultra-slim Symmetry MagSafe Clear series, the iPhone 15 transparent case that's easy to install and has 3 times as many drops as military standard ( MIL-STD-810G 516.6 ). OtterBox Symmetry MagSafe case has raised edges to protect your smartphone's camera and screen from serious drops and scrapes. Clear case shows off your phone's elegant design while protecting against drops, dings and scratches.
- Made from 50% recycled plastic, OtterBox Symmetry MagSafe Clear Series provides flawless, sleek and stylish protection from scratches and cracks.
- Symmetry MagSafe Clear cases guarantee MagSafe compatibility thanks to built in magnets perfectly aligned to make wireless charging faster and easier than ever before. Seamlessly attach and remove MagSafe accessories through built in magnets.
- The crystal-clear Premium Glass Screen Protector is an ultra-thin tempered glass, made with fortified material technology to withstand drops, breaks, scratches and daily wear. Plus, it’s fingerprint resistant, so you can touch, tap and swipe while your screen stays smudge-free.
- OtterBox Premium Glass delivers advanced anti-scratch defence for vivid screen clarity and shatter-resistant drop protection..Fortified material resists splintering and the reinforced edges prevent chipping, while maintaining touch sensitivity and display clarity. Compatible with iPhone 15
Enhanced durability
Crafted from polycarbonate and synthetic rubber, this protective cover offers a rigid case design that withstands the rigors of daily use. Its compliance with MIL-STD-810G 516.6 standards ensures your device is safeguarded against bumps and drops, providing peace of mind in any situation. -
Magnetic integration
Designed with built-in magnets, this case is fully compatible with MagSafe accessories, allowing for seamless attachment and enhancing the user experience. The convenience of magnetically attaching your cell phone to various mounts and accessories has never been easier. -
Thoughtful design
Featuring a raised camera bezel, this back cover not only protects your camera lens from scratches but also ensures the integrity of your photos. The 5G compatibility ensures that your device's connectivity is not hindered, offering both protection and performance.
- OtterBox Symmetry Series - back cover for mobile phone
- Product Type
- Back cover for mobile phone
- 7.91 cm x 1.335 cm x 15.29 cm
- 40.71 g
- Material
- Polycarbonate, synthetic rubber
- Clear
- Product Recycled Content
- 50 % - made of recycled plastic
- Limited lifetime warranty
- Designed For
- Apple iPhone 15
- 7.91 cm
- 1.335 cm
- 15.29 cm
- 40.71 g
- Material
- Clear
Carrying Case
- Protective cover
- Recommended Use
- For mobile phone
- Protection
- Bump protection, drop+ protection
- Cover Type
- Back cover
- 5G compatibility, raised camera bezel, rigid case design, built in magnets
- MILD-STD-810G 516.6
- Designed For
- Apple iPhone 15
