OtterBox Symmetry Clear MagSafe + Premium Glass AM iPhone 15
Quicklinx: HFQWWS00 Mfr#: 78-81257
  • Protect your smartphone with ultra-slim Symmetry MagSafe Clear series, the iPhone 15 transparent case that's easy to install and has 3 times as many drops as military standard ( MIL-STD-810G 516.6 ). OtterBox Symmetry MagSafe case has raised edges to protect your smartphone's camera and screen from serious drops and scrapes. Clear case shows off your phone's elegant design while protecting against drops, dings and scratches.
  • Made from 50% recycled plastic, OtterBox Symmetry MagSafe Clear Series provides flawless, sleek and stylish protection from scratches and cracks.
  • Symmetry MagSafe Clear cases guarantee MagSafe compatibility thanks to built in magnets perfectly aligned to make wireless charging faster and easier than ever before. Seamlessly attach and remove MagSafe accessories through built in magnets.
  • The crystal-clear Premium Glass Screen Protector is an ultra-thin tempered glass, made with fortified material technology to withstand drops, breaks, scratches and daily wear. Plus, it’s fingerprint resistant, so you can touch, tap and swipe while your screen stays smudge-free.
  • OtterBox Premium Glass delivers advanced anti-scratch defence for vivid screen clarity and shatter-resistant drop protection..Fortified material resists splintering and the reinforced edges prevent chipping, while maintaining touch sensitivity and display clarity. Compatible with iPhone 15
  • Enhanced durability
    Crafted from polycarbonate and synthetic rubber, this protective cover offers a rigid case design that withstands the rigors of daily use. Its compliance with MIL-STD-810G 516.6 standards ensures your device is safeguarded against bumps and drops, providing peace of mind in any situation.
  • Magnetic integration
    Designed with built-in magnets, this case is fully compatible with MagSafe accessories, allowing for seamless attachment and enhancing the user experience. The convenience of magnetically attaching your cell phone to various mounts and accessories has never been easier.
  • Thoughtful design
    Featuring a raised camera bezel, this back cover not only protects your camera lens from scratches but also ensures the integrity of your photos. The 5G compatibility ensures that your device's connectivity is not hindered, offering both protection and performance.
OtterBox Symmetry Series - back cover for mobile phone
Back cover for mobile phone
7.91 cm x 1.335 cm x 15.29 cm
40.71 g
Material
Polycarbonate, synthetic rubber
Clear
Product Recycled Content
50 % - made of recycled plastic
Apple iPhone 15
7.91 cm
1.335 cm
15.29 cm
40.71 g
Material
Clear
Carrying Case
Protective cover
Recommended Use
For mobile phone
Protection
Bump protection, drop+ protection
Cover Type
Back cover
5G compatibility, raised camera bezel, rigid case design, built in magnets
MILD-STD-810G 516.6
Apple iPhone 15
