OtterBox Symmetry Clear iPhone 15/14/13 - Clear
Quicklinx: HFKPWS00 Mfr#: 77-92674
Product Range: OtterBox Symmetry Series
£14.23 ex VAT
£17.07 inc VAT
OtterBox Symmetry Series - back cover - Apple iPhone 13, 14, 15
  • Slim and sleek design
    The OtterBox Symmetry Series case offers an ultraslim and sleek design, ensuring your cell phone remains lightweight and pocket-friendly, without sacrificing protection.
  • Enhanced protection
    Engineered with raised edges and certified with MIL-STD-810G 516.6 standards, this protective cover offers superior protection, safeguarding your device from accidental falls and impacts.
  • Wireless convenience
    Designed with modern needs in mind, this case supports wireless charging and is compatible with MagSafe, allowing for effortless charging without the need to remove the case.
  • Eco-friendly choice
    Committed to sustainability, the OtterBox Symmetry Series case is made of 50% recycled plastic, making it a responsible choice for environmentally conscious consumers.
OtterBox Symmetry Series - back cover for mobile phone
Back cover for mobile phone - MagSafe compatibility
7.91 cm x 1.335 cm x 15.29 cm
38.71 g
Clear
Product Recycled Content
50 % - made of recycled plastic
7 years warranty
7.91 cm
1.335 cm
15.29 cm
38.71 g
Package Details
Pro pack
Clear
Carrying Case
Protective cover
Recommended Use
For mobile phone
Protection
Drop+ protection
Cover Type
Back cover
Wireless charging support, raised edges, 5G compatibility, ultra-sleek design, slim design
MagSafe Compatibility
MIL-STD-810G 516.6
7 years
Used stock
What is used stock?
Accessories Packaging Functional Software Manuals
Ref: HFKP 050754
Condition: Customer return - item has been opened but is in excellent condition
This part of the stock item is not applicable e.g. it might not include accessories or software as standard  This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is not present or functional  This part of the stock item is not present or functional  £1.89
Legend
  • This part of the stock item is present and in good conditionThis part of the stock item is present and in good condition
  • This part of the stock item is not present or functionalThis part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standardThis part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.This item has not been tested.
Brand: OtterBox
Stock Status: Used Stock
