Show off your phone with the slim profile of Symmetry Series, the clear iPhone 13 Pro case that coordinates with any look. Fortified with drop protection and easy to install, Symmetry Series is designed so your phone's features work just like you expect. Additionally, a silver-based antimicrobial additive is integrated into the case that helps inhibit microbial growth and defends the case exterior against many common bacteria. It's style that's ready to grab and go wherever the day takes you.
Sleek protection
The OtterBox Symmetry Series Clear case combines a one-piece design with polycarbonate and synthetic rubber materials, offering a sleek yet durable solution for cell phone protection. Its ultraslim profile doesn't add bulk, ensuring your device remains easy to handle and pocket-friendly. -
Enhanced durability
Equipped with DROP+ technology and compliant with MIL-STD-810G 516.6 standards, this case is designed to withstand drops and bumps. The raised edges provide additional screen and camera protection, minimizing the risk of scratches and damage from everyday use. -
5G compatibility
Designed to accommodate mobile technology, this case ensures full 5G compatibility, allowing you to enjoy high-speed connectivity without interference. Its clear material showcases the phone's design while offering scratch-resistant protection.
- OtterBox Symmetry Series Clear - back cover for mobile phone
- Product Type
- Back cover for mobile phone
- Material
- Polycarbonate, synthetic rubber
- Clear
- Designed For
- Apple iPhone 13 Pro
- Material
- Clear
Carrying Case
- Protective cover
- Recommended Use
- For mobile phone
- Protection
- Scratch-resistant, drop protection
- Cover Type
- Back cover
- Raised edges, DROP+ technology, one-piece design, 5G compatibility, ultra-slim
- MIL-STD-810G 516.6
- Designed For
