You don't have to choose between a protective case and a stylish one. Symmetry Series is the slim and protective case that shows off your style. All of your phone's buttons, features and functions work flawlessly. Additionally, a silver-based antimicrobial additive is integrated into the case that helps inhibit microbial growth and defends the case exterior against many common bacteria. And, Symmetry Series is easy to remove and install. Which is great because with all of the colors, you need more than just one. From cute and fun to daring and dazzling, Symmetry Series is the expressive case that's slimmer than ever, as protective as always.
Robust protection
Crafted from polycarbonate and synthetic rubber, the OtterBox Symmetry Series Clear offers a protective cover designed to safeguard your cell phone from daily mishaps. Its construction ensures durability and resilience against drops, making it an ideal companion for your device -
Durability standards
Meeting the rigorous MIL-STD-810G 516.6 standards, this back cover provides peace of mind with its proven protection. Its antimicrobial properties further protect by inhibiting the growth of bacteria on the surface of your phone -
Sleek design
The clear design of the OtterBox Symmetry Series Clear showcases the beauty of your cell phone while providing protection. Its slim profile does not add bulk, ensuring your device remains easy to handle and store
- OtterBox Symmetry Series Clear ProPack Packaging - back cover for mobile phone
- Product Type
- Back cover for mobile phone
- 7.82 cm x 1.19 cm x 15.8 cm
- Material
- Polycarbonate, synthetic rubber
- Clear
- Limited lifetime warranty
- Designed For
- Samsung Galaxy S21 5G
- 7.82 cm
- 1.19 cm
- 15.8 cm
- Material
- Clear
Carrying Case
- Protective cover
- Recommended Use
- For mobile phone
- Protection
- Drop-proof, antimicrobial
- Cover Type
- Back cover
- MIL-STD-810G 516.6
- Designed For
