You don't have to choose between a protective case and a stylish one. Symmetry Series Clear is the sleek and protective case that shows off your style. All of your phone's buttons, features and functions work flawlessly. And Symmetry Series Clear is easy to remove and install. From cute and fun to daring and dazzling, Symmetry Series Clear is the slim iPhone 14 Pro Max clear case that delivers trusted OtterBox protection.
Eco-friendly construction
Crafted from 50% recycled plastic, polycarbonate, and synthetic rubber, this case not only protects your device but also supports environmental sustainability. -
Advanced protection
Featuring DROP+ technology and compliance with MIL-STD 810G 516.6 standards, this case offers superior drop protection. Its raised edges safeguard the screen and camera from scratches and impacts. -
Wireless convenience
Designed with an ultra-sleek profile that supports wireless charging, allowing you to power up your device without removing the case. MagSafe compatibility ensures a seamless charging experience. -
Antimicrobial feature
The antimicrobial property of the case actively inhibits the growth of bacteria on your phone, ensuring a cleaner surface and added peace of mind in daily use.
- OtterBox Symmetry Series ProPack Packaging - back cover for mobile phone
- Product Type
- Back cover for mobile phone - MagSafe compatibility
- 8.38 cm x 1.41 cm x 16.69 cm
- Material
- Polycarbonate, synthetic rubber, 50% recycled plastic
- Clear
- Limited lifetime warranty
- Designed For
- Apple iPhone 14 Pro Max
- 8.38 cm
- 1.41 cm
- 16.69 cm
- Package Details
- Polybag
- Material
- Clear
Carrying Case
- Protective cover
- Recommended Use
- For mobile phone
- Protection
- Drop protection
- Cover Type
- Back cover
- Wireless charging support, raised edges, DROP+ technology, 5G compatibility, ultra-sleek design
- MagSafe Compatibility
- MIL-STD 810G 516.6
- Designed For
