OtterBox Symmetry Clear Apple iPhone 13 Pro - clear
Quicklinx: GVFMWS00 Mfr#: 77-84289
£14.08 ex VAT
£16.89 inc VAT
You don't have to choose between a protective case and a stylish one. Symmetry Series is the slim and protective case that shows off your style. All of your phone's buttons, features and functions work flawlessly. Additionally, a silver-based antimicrobial additive is integrated into the case that helps inhibit microbial growth and defends the case exterior against many common bacteria. And, Symmetry Series is easy to remove and install. Which is great because with all of the colors, you need more than just one.
  • Sleek protection
    The OtterBox Symmetry Series Clear case combines a one-piece design with polycarbonate and synthetic rubber materials, offering a sleek yet durable protection for your cell phone. Its ultraslim profile doesn't add bulk, ensuring your device remains easy to handle and pocket-friendly.
  • Enhanced durability
    Equipped with DROP+ technology and meeting the MIL-STD-810G 516.6 standards, this case is designed to withstand drops and bumps. Raised edges safeguard your screen and camera, providing peace of mind in daily use.
  • Wireless convenience
    Designed with modern needs in mind, this case supports wireless charging, allowing you to power up your device without removing the case. Its MagSafe compatibility ensures a seamless experience with MagSafe accessories.
  • Eco-friendly choice
    With 50% of the case made from recycled plastic, choosing the OtterBox Symmetry Series Clear case is a step towards sustainability. Its antimicrobial protection also adds an extra layer of safety by inhibiting microbial growth on your case.
OtterBox Symmetry Series Clear - back cover for mobile phone
Back cover for mobile phone - MagSafe compatibility
Material
Polycarbonate, synthetic rubber
Clear
Product Recycled Content
50 % - made of recycled plastic
Apple iPhone 13 Pro
Material
Clear
Carrying Case
Protective cover
Recommended Use
For mobile phone
Protection
Antimicrobial, drop protection
Cover Type
Back cover
Wireless charging support, raised edges, DROP+ technology, one-piece design, 5G compatibility, ultra-slim
MagSafe Compatibility
MIL-STD-810G 516.6
Apple iPhone 13 Pro
Product Range: OtterBox Symmetry Series Clear
Brand: OtterBox
