OtterBox Symmetry Clear Apple iPhone 13 - clear
Quicklinx: GVF2WS00 Mfr#: 77-85316
Type: Case / Cover
Product Range: OtterBox Symmetry Series
Product Model: Apple iPhone 13
£15.23 ex VAT
£18.27 inc VAT
You don't have to choose between a protective case and a stylish one. Symmetry Series is the slim and protective case that shows off your style. All of your phone's buttons, features and functions work flawlessly. Additionally, a silver-based antimicrobial additive is integrated into the case that helps inhibit microbial growth and defends the case exterior against many common bacteria. And, Symmetry Series is easy to remove and install. Which is great because with all of the colors, you need more than just one.
  • Enhanced durability
    Equipped with DROP+ technology and compliant with MIL-STD-810G 516.6 standards, this OtterBox Symmetry Series case offers robust protection against drops and impacts, ensuring your cell phone remains in pristine condition.
  • Sleek design
    The one-piece design combines a hard polycarbonate exterior with a soft synthetic rubber grip, creating an ultraslim profile that doesn't add bulk to your device. Raised edges safeguard your screen and camera from scratches.
  • Wireless convenience
    Designed with modern needs in mind, this case supports wireless charging, allowing you to power up your device without removing the case. Its MagSafe compatibility ensures a seamless charging experience.
  • Eco-friendly choice
    Made of 50% recycled plastic, this case not only protects your phone but also contributes to environmental sustainability. Its antimicrobial protection further ensures a cleaner surface by inhibiting the growth of bacteria on the case.
OtterBox Symmetry Series - back cover for mobile phone
Back cover for mobile phone - MagSafe compatibility
Material
Polycarbonate, synthetic rubber
Clear
Product Recycled Content
50 % - made of recycled plastic
Apple iPhone 13
Material
Clear
Carrying Case
Protective cover
Recommended Use
For mobile phone
Protection
Antimicrobial, drop protection
Cover Type
Back cover
Wireless charging support, raised edges, DROP+ technology, one-piece design, 5G compatibility, ultra-slim
MagSafe Compatibility
MIL-STD-810G 516.6
Apple iPhone 13
Type: Case / Cover
Brand: OtterBox
