OtterBox Symmetry Apple iPhone 13 Pro - black
Quicklinx: GVFLWS00 Mfr#: 77-84208
Device Type: Apple
Type: Case / Cover
Product Range: OtterBox Symmetry Series
Product Model: Apple iPhone 13 Pro
£14.26 ex VAT
£17.11 inc VAT
You don't have to choose between a protective case and a stylish one. Symmetry Series is the slim and protective case that shows off your style. All of your phone's buttons, features and functions work flawlessly. Additionally, a silver-based antimicrobial additive is integrated into the case that helps inhibit microbial growth and defends the case exterior against many common bacteria. And, Symmetry Series is easy to remove and install. Which is great because with all of the colors, you need more than just one.
  • Enhanced durability
    Equipped with DROP+ technology and meeting MIL-STD-810G 516.6 standards, this OtterBox Symmetry Series case offers robust protection against drops, ensuring your cell phone withstands the rigors of daily use.
  • Sleek design
    The one-piece design combines a hard polycarbonate exterior with a soft synthetic rubber interior, providing a perfect balance between protection and style. Its ultraslim profile doesn't add bulk, preserving the sleek look of your device.
  • Functional protection
    Raised edges safeguard your screen and camera from scratches and cracks, while the case's wireless charging support means you can power up without removing the cover. Antimicrobial technology helps keep your device clean.
  • MagSafe compatibility
    Designed with MagSafe compatibility, this case ensures you can use all your favorite MagSafe accessories without any hassle, enhancing the functionality of your cell phone.
OtterBox Symmetry Series - back cover for mobile phone
Back cover for mobile phone - MagSafe compatibility
Material
Polycarbonate, synthetic rubber
Apple iPhone 13 Pro
Material
Carrying Case
Protective cover
Recommended Use
For mobile phone
Protection
Scratch protection, drop+ protection
Cover Type
Back cover
Wireless charging support, raised edges, DROP+ technology, one-piece design, ultra-slim
MagSafe Compatibility
MIL-STD-810G 516.6
Lifetime
Apple iPhone 13 Pro
Device Type: Apple
Type: Case / Cover
Brand: OtterBox
