Ultra-thin, resilient necklace phone case protects against drops and fumbles. This slim case is thoughtfully designed to provide seamless interaction with MagSafe chargers and accessories. Its solid one-piece form is precision-fit to your phone and its soft touch edges provide great grip. The case installs easily, while the necklace feature delivers reliable carrying options and helps to prevent drops. Wrap your phone in the trusted and stylish protection of React Series Necklace MagSafe Case.
Eco-friendly choice
With 50% of its composition made from recycled plastic, this case not only protects your cell phone but also the planet. Its recyclable packaging further emphasizes a commitment to environmental sustainability. -
Advanced protection
Designed to offer superior safety, the OtterBox React Series case features protection, ensuring your device remains unscathed from accidental falls and bumps. -
Sleek design
The ultraslim, one-piece design with soft touch edges and a slim profile ensures your cell phone remains lightweight and easy to handle, without compromising on protection. -
Wireless convenience
Fully compatible with wireless charging and MagSafe, this case allows you to charge your device without the hassle of removing the case, offering convenience and functionality. -
5G compatibility
Engineered to support 5G connectivity, this case ensures that you can enjoy fast network speeds without interference, keeping you connected wherever you go.
- OtterBox React Series - back cover for mobile phone
- Product Type
- Back cover for mobile phone - MagSafe compatibility
- 7.82 cm x 1.07 cm x 16.07 cm
- 63.5 g
- Material
- Plastic
- Black
- Product Recycled Content
- 50 % - made of recycled plastic
- 7 years warranty
- Designed For
- Apple iPhone 14
- 7.82 cm
- 1.07 cm
- 16.07 cm
- 63.5 g
- Package Type
- Retail
- Material
- Plastic
- Black
Carrying Case
- Protective cover
- Recommended Use
- For mobile phone
- Protection
- Drop+ protection
- Cover Type
- Back cover
- Carrying Strap
- Rope
- Shipping Dimensions (WxDxH) / Weight
- 19.68 cm x 10.79 cm x 3.81 cm
- Ultra-thin, slim design, one-piece design, soft touch edges, wireless charging support, 5G compatibility, recyclable packaging
- MagSafe Compatibility
- 7 years
- Designed For
- Apple iPhone 14
