OtterBox React Series MagSafe for iPhone 16 - Clear
Quicklinx: J59LWS00 Mfr#: 77-96246
£8.85 ex VAT
£10.62 inc VAT
Ultra-thin and resilient, React Series is the MagSafe case that protects your phone from drops and scrapes. Its solid, one-piece form is precision-fit for your phone and its soft-touch edges provide a sure grip. Built-in magnets let you snap to MagSafe accessories, opening new ways to use your phone. Plus, the case installs fast, and it slides in and out of pockets seamlessly. Wrap your phone in the trusted protection of React Series for MagSafe.
  • Durable Protection
    The DROP+ technology offers robust protection, designed to absorb shocks and mitigate the effects of drops, ensuring your phone remains safe in everyday situations.
  • Eco-Friendly Materials
    Constructed from 45% recycled plastic, this case supports sustainability while providing reliable protection for your phone.
  • Wireless Charging Compatibility
    Integrating built-in magnets allows seamless wireless charging, making it effortless to keep your device powered without the need to remove the case.
  • Precision Fit
    Engineered to provide a snug fit for your device, this case ensures comprehensive coverage while maintaining easy access to buttons and ports.
  • Comfortable Grip
    With soft touch edges, this case enhances grip, reducing the chances of accidental drops.
OtterBox React Series - back cover for mobile phone
Back cover for mobile phone
Carrying Case
Protective cover
Recommended Use
For mobile phone
Cover Type
Back cover
Used stock
What is used stock?
Accessories Packaging Functional Software Manuals
Ref: J59L 051387
Condition: Customer return - item has been used and shows signs of use
This part of the stock item is not applicable e.g. it might not include accessories or software as standard  This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.  This part of the stock item is present and in good condition  This part of the stock item is not applicable e.g. it might not include accessories or software as standard  This part of the stock item is not applicable e.g. it might not include accessories or software as standard  £6.00
Legend
  • This part of the stock item is present and in good conditionThis part of the stock item is present and in good condition
  • This part of the stock item is not present or functionalThis part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standardThis part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.This item has not been tested.
Brand: OtterBox
Stock Status: Used Stock
