The OtterBox React Series protective cover is designed for cell phones, providing reliable protection without compromising on style. This ultra-thin back cover offers a precision fit and features soft touch edges for a comfortable grip. Built to withstand drops and scrapes, the case complies with MIL-STD-810G 516.6 standards, ensuring durability and security.
In addition to providing robust protection, this one-piece design supports wireless charging, making it convenient for everyday use. Made of 45% recycled plastic, this case protects your device and contributes to sustainability. Choose the OtterBox React Series for a functional and eco-friendly solution.
Durable Protection
Built to comply with MIL-STD-810G 516.6 standards, this case provides reliable protection against drops and scrapes, ensuring your device stays safe. -
Wireless Charging Compatible
The case's design supports wireless charging, allowing for convenient charging without the need to remove the cover. -
Eco-Friendly Materials
Constructed from 45% recycled plastic, this case helps reduce environmental impact while maintaining durability. -
Sleek Design
Featuring an ultra-thin profile and soft touch edges, this case delivers a modern look and feel without adding bulk. -
Precision Fit
Manufactured for a precise fit, this one-piece design ensures that all buttons and ports are easily accessible while keeping your phone protected.
- OtterBox React Series - back cover for mobile phone
- Product Type
- Back cover for mobile phone
- 8.27 cm x 1.16 cm x 16.78 cm
- 39.2 g
- Material
- Plastic
- Clear
- Product Recycled Content
- 45 % - made of recycled plastic
- 7 years warranty
- Designed For
- Samsung Galaxy S25 Ultra
- 8.27 cm
- 1.16 cm
- 16.78 cm
- 39.2 g
- Package Details
- ProPack
- Material
- Plastic
- Clear
Carrying Case
- Protective cover
- Recommended Use
- For mobile phone
- Protection
- Drop+ protection, scrape protection
- Cover Type
- Back cover
- Ultra-thin, one-piece design, precision fit, soft touch edges, wireless charging support
- MIL-STD-810G 516.6, UL 2809-2
- Limited warranty - 7 years
- Designed For
