The OtterBox React Series protective cover combines sleek style with robust protection for cell phones. Designed as an ultra-thin back cover, it features soft touch edges that enhance grip and comfort. With a precision fit and a one-piece design, this case supports wireless charging while ensuring reliable drop and scrape protection, meeting the MIL-STD-810G 516.6 and UL 2809-2 standards. Crafted from 45% recycled plastic, this eco-friendly option protects your device and contributes to sustainability. It is a suitable choice for those who value both functionality and environmental responsibility, making it a reliable companion for everyday use.
Slim profile
The ultra-thin construction ensures that the case adds minimal weight and bulk to the phone, allowing for easy handling and portability. -
Eco-friendly material
Made from 45% recycled plastic, this case supports sustainable practices while delivering reliable protection. -
Military-grade protection
Complying with MIL-STD-810G 516.6 standards, this case is engineered to withstand drops and provide robust protection from daily wear and tear. -
Precise fit
Designed with precision in mind, this case ensures all ports, buttons, and features remain accessible while providing a snug and secure fit. -
Wireless charging compatible
Designed to support wireless charging, this case allows for easy power-ups without the hassle of removing the cover.
- OtterBox React Series - back cover for mobile phone
- Product Type
- Back cover for mobile phone
- 7.55 cm x 1.06 cm x 15.19 cm
- 32.07 g
- Material
- Plastic
- Black crystal
- Product Recycled Content
- 45 % - made of recycled plastic
- 7 years warranty
- Designed For
- Samsung Galaxy S25
- 7.55 cm
- 1.06 cm
- 15.19 cm
- 32.07 g
- Package Details
- ProPack
- Material
- Plastic
- Black crystal
Carrying Case
- Protective cover
- Recommended Use
- For mobile phone
- Protection
- Drop+ protection, scrape protection
- Cover Type
- Back cover
- Ultra-thin, one-piece design, precision fit, soft touch edges, wireless charging support
- MIL-STD-810G 516.6, UL 2809-2
- Limited warranty - 7 years
- Designed For
